Post new topic Reply to topic  [ 683 posts ]  Go to page Previous  1 ... 42, 43, 44, 45, 46
 Post subject: Re: Parts Shop MAX ~ GY6 swap harness
PostPosted: Fri Jul 17, 2015 9:55 am
Having a problem understanding the wires on a 11 pole stator
I have the plug that's got the yellow/black already together in the plug
Anyone who can clearly tell me what colours go together I would really appreciate your help
Stator plug = yellow & black together
Green/black
Yellow/white
Pink
Harness end =
Yellow
White
Green
Pink
Which wire colour goes where
Can get the bike turning over from the button but keeps cooking the green wire
Or blowing fuse
Update :(
Instructions for harness states that if you only have one yellow from your stator hook it up to black/yellow and don't use pink and yellow/white
Which I done but doesn't say where green goes
If I wire the green to any other colour on harness my green still cooks
Build Thread
viewtopic.php?f=76&t=90042
PostPosted: Sun Jul 19, 2015 3:13 pm
Green/black
Yellow/white
Pink
Harness end =
Yellow
White
Green
Pink
Or blowing fuse
Update :(
Was a bad Earth :popcorn:
Build Thread
PostPosted: Mon Jul 20, 2015 12:48 pm
Just posting to cross my t's and dot my i's.
I have the 8 pole stator on my gy6, when plugging my 4-pin harness plug to the 4-pin stator plug, my yellow/white(harness) was connected to my green(stator). Since I'm not running the 11-pole, I took the yellow/white out and capped it off. Which in turn, freed up my green(stator). So I'm hooking up my green/black(harness) to the stator green. Just double checking that this is correct.
Input please, thanks
P.s. No need to post the directions on page 1, I've read them, as well as the other 40+ pages in the thread.
Edit** I was told the wiring I did is correct. What power source is everyone running their tach from?
this RUdiCKuloUS build
http://totalruckus.com/phpBB3/viewtopic.php?f=93&t=94739
PostPosted: Wed Dec 16, 2015 11:07 am
We now offer Plug & Play upgrade for the DanMax Harness.
DROWsports will complete the wiring of the Dan Max GY6 Harness making it completely Plug and Play to the factory Ruckus control and plugs. This mean no more butt connectors and no more figuring out which wires going to what every time you unplug it. You can save 100% of your factory main harness, no need to cut and reuse any part of the main harness. (*Because we will wire up the GY6 Swap Harness to factory Ruckus Controls and Head Light plugs we recommend you saving those two items)
-OEM Ruckus Left Hand Control Switch Plug*
-OEM Ruckus Headlights Plug*
-OEM Ruckus Ignition Plug
-OEM Ruckus Tail Light Plug
-GY6 11 Pole Stator
http://www.drowsports.com/ruckus-gy6-swap-harness/
www.DROWsports.com
My 232cc GY6 Ruckus
PostPosted: Thu Feb 11, 2016 2:34 am
Hey i just got my stage 6 controls. I think i have all the left side switch down, but for the right side im planning to use the switch by the throttle for start switch. If i do that, can i just ditch the kill switch and just use the key to turn off the motor or will i still need a kill switch wired up to start the bike?
PostPosted: Thu Feb 11, 2016 11:27 am
Yes, you'll be turning the bike off using the key. Make sure to have the "Kill Switch" wire on the harness open and not looped.
www.DROWsports.com
My 232cc GY6 Ruckus
PostPosted: Tue Jun 28, 2016 2:56 pm
Stage 6 wiring ok. I have 11 pole stator with 5 pin rectifier.
For some reason it's not charging. It drop to 12.3 at idle and I rev engine up around 3krpm but the voltage doesn't go up at all. With headlight on stay at 12.5 and off 12.7 at idle. Is my stator bad? Stage 6 control I wire purple to black DC power harness wire and brown to a power wire to my starter ignition relay. That's the only way my headlight work.
PostPosted: Fri Jun 16, 2017 8:11 am
does anyone have the original pictures on the first post? I just bought a used ruckus and the danmax harness its all messed up and I want to try salvaging it instead of buying a new one. If someone has close up pictures of the harness with each set of wires labelled that would be awesome too
