StandardFunction's parts galore
Riding season is in full effect, don't get caught looking like the rest of your buddy's. Bringing fresh colors and parts to the scene, that's our standard... and here's your function. DARE to be different.
www.StandardFunctions.com8/17/10ATR rear lowdown shocks back in stock as well as a limited run of brand new OEM BWS/Z125 front headlight conversions.
215mm-245mm ATR rear shocks colorways
*Original* Black anodize body with red spring
*New* Black anodize body on Black spring
*New* Gold anodize body on Black spring
Photo coming soon
8/10/10Rideslw Tee's now available. Get them while they last!
7-30-10ATR 10x7 gy6 swap kit is back by popular demand, these are limited and for everyone who have been waiting anxiously we are having a special discount price with a
$100 rebate. For any questions, feel free to PM us @ fatphos and minkus or email us at StandardFunctions@gmail
ALSO don't forget to ask about our optional wheel replacements for our ATR hubs.
Also back in stock and New items: ATR gy6 universal hub
NEW ATR front hub universal for both
10mm and 12mm axlesWill be posted on the
http://www.standardfunctions.com real soon
7-15-10
Gojin LED cylinder light set : comes in your choice of
Red or
Amber yellow LEDS.
Gojin R6 tail lamps in various color ways
Gojin ZR tail lamps in various color ways
LED licenses plate bolts
7-3-10:July 4th Weekend Special! FREE SHIPPING TO THE WHOLE US with orders over $100!Also, just restocked:
-ATR GY6 Plug and Play Wire Harness (to show appreciation to those who long waited, we have a special price for this weekend only!)
-GY6 Short Axle
-Koso GY6 Kickstart Lever
Have a great Independence Day weekend!
6-24/10:We're tired of seeing stock Ruck's, do yourself a favor and get a complete ATR 50cc engine extension kit at an awesome price of $80. exclusively at StandardFunctions.com
4-25-10:Don't miss the chance to save up to 15%! A few days left!
New Arrivals:
Exact CNC valve covers for Zuma 125!
Koso Kickstart lever for GY6!
MTRT Variator Set for GY6!
BTX GY6 Bazooka Exhaust!
GS Racing Variator!
+ more! Check out our website!NEW & COMPLETE ATR Front Disc Brake kit w/ Aluminum Triple Tree UPDATE: January 14 2010Heres some sample photos before they get on our website, with that said.... and all the months of waiting and questions, we will personally take care of the first 10 buyers with a special TR discount
retail : $900
TR SPECIAL :
$850 *keep reading...
*NEWLY designed 220mm 2pc floating rotor
*NEW 7 way adjustable front forks
*NEW gloss black anodize and gold anodize finish
*NEW pair of 12mm Axle pullers
*NEW aluminum tree. Standard OEM Ruckus/Zoomer size. No needed spacers like the DIO type tree.
*Titanium finish rotor bolts
*Steel braided Brake line
*Honda DIO type wheel
*Master Cylinder
*Speedometer mount & cable
** Will require current steering cone from stock Triple tree **
http://webservices.motorsportdealers.com/parts/partImages/HOM/2/14GEZ3/ILLUST/GEZ4F/0800A.Gif pc #22
ATR's new LOWdown rear shock * 215mm - 245mm height adjustment
* short and strengthened with a longer inside stroke for comfort and ride quality.
* New color options
-Black with red spring
-Red with black spring
^ Colors are interchangeable for the guys who get funky with theirs.
retail : $150
TR SPECIAL : $140
Ming@standardfunctions.com ATR GY6 Non-Fatty Engine mount kit and Swap and UPDATES: October 28, 2009-ATR GY6 Non-Fatty Engine mount and Swap- Have been released!
-ATR GY6 Daytona/4x140mm Disc Hub have been released!
Direct AIM orders:
fatphos or
SFxminkusHave something you want but don't see listed? Feel free to contact us with what you want, we may be able to order it for you!
Dealers inquiry welcome!
ATR GY6 Engine mount kit and swap!ATR GY6 Daytona/4x140mm Disc Brake Hub and Rear Disc brake conversion!
ATR GY6 Plug and Play harness
We found these in a catalog and decided to order them. Same style as the Kitaco units and the quality is very good. It's very thick and sturdy, high gloss to match the rest of the carbon fiber items that we carry and there is no ugly line down the middle of the fender!
Note: minor widening of the holes for the mounting hardware to some fender may be needed due to the tight fit.
Carbon Fiber front fender with all mounting hardware!
Black
Red
Yellow
Plain fiber glass fender with all mounting hardwares!
Ready for paint!
GY6 Magnetic Flywheel puller-
GY6 Starter bandix/clutch nut remover! Stop damaging your starter clutch nut and make life easier with the use of this tool! Can be used with 1/2" rachets or impact guns
GY6 Exhaust gasket- same materials as those that are used for cars!
Stage 6 velocity stack for stock GY6 carb. Anodized blue only.
Peep it getting properly used on Topanga:
BTX Big Bore GY6 header. Made to get the most power of out your big bored GY6!
GoJin carbon fiber oil pressure relief can-
Full aluminum can with carbon fiber and stainless steel exterior.
Comes include with all hardware, clear hoses, clamps, etc.
Will fit 50cc and GY6's
GoJin carbon fiber pressure catch can-
Comes include with all hardware, stainless steel braided hose with fittings, etc.
Will fit 50cc and GY6's:
GY6 Long case drum brake pads-
GY6 Stainless Steel covered throttle cable 79inches long
This throttle cable will work with your stock 24mm GY6 carb. and stock throttle/cam type throttles.
Dio front suspension 190mm floating brake rotor and caliber adapter
Replace your small 160mm stock rotor with this upgraded 190mm floating rotor! This rotor will work with your OEM Honda Dio brake caliber and forks, no need to purchase 2 piston caliber when the OEM caliber is more then enough for any Ruckus' or Dio, even with a swapped!
NOTE: This rotor and caliber adapter unit will not work with the P30 type 2 piston calibers.
Chrome face/Blue rivets
Bronze face
Z125 guys, are you tired of looking like your other factory U.S. buddies?
Brand New yamaha BWS ASIA/JDM front ends
some pictures for now
Mikuni vacuum fuel pump
OEM GY6 equipped scooter vacuum fuel pump
11 pole GY6 stator regulator/rectifier
Large Valve GY6 head
Larger intake and exhaust ports and larger valves.
High lift A14 camshaft for GY6
63mm big bore cylinder and piston set
Includes: 63mm ceramic coated piston, 63mm cylinder head, piston rings set, wrist pin, cylinder gasket, and head gasket.
Note: Will work with the 150cc cases, boring of those cases is required.
Special power package combo is available, you can purchase the large head, high lift cam, and big bore set. Email us for info!Yamaha Zuma 125 58.5mm 155cc big bore kit
Includes: Piston, Piston rings, wrist pin, cylinder head, and gaskets.
StandardFunctions first. A BIG heads up to you Gy6 and Zuma swapped folksATR's new hubs are professionally hand made with T6061 aluminum and steel lining is pressed in for brake surface. All hubs are anodized silver and they are limited quantity!
Zuma/Grand Axis rear hub
Will accept ANY Daytona wheels or similar style. Has two bolt patterns so you can drill your rims according to their design. Has both 4 bolt and 5 bolt pattern to accommodate 5 star wheel, 8 hole wheel, full dish, etc.
Note: Boring the center hole of the rim is needed. We do offer this service as well if needed, please email us for details.
GY6 Daytona Drum hub
Will accept ANY Daytona wheels or wheels with a 4x140mm bolt pattern.
GY6 Universal drum hub
ATR wanted to make it easier for everyone that wants to rock dope wheels by making a drum hub with 3 different bolt patterns. This hub will accept 4x102mm, 4x110mm, and 4x130mm, which is pretty much all of the popular ATV bolt patterns out there, no need for headache looking for the correct wheel with the correct bolt pattern and offset to fit your engine.
You can fit the following size wheels!
10x5, 10x7, 10x8.
12x5, 12x7, 12x8.
Note: Rays lug nuts are not included!
ATR complete bolt on engine mount for Zuma and Grand Axis: Coming soon!
A evolution of the ATR GY6 fatty engine mount is now available for the 2 stroke swaps! This engine mount will allow you to run your regular wheels (non fatty) with your 2 stroke monster. The mount is a direct bolt on to your Ruckus/Zoomer so you don't need to weld anything to the frame.
ATR GY6 Custom 10x7 wheel kit w/ rear disc brake conversion
Complete bolt on kit!
Note:
Removal of the coolant tank tab is required.
In-house modification to the swing arm is necessary so we prefer you to purchase the complete make over.
-Brand new long case GY6 engine w/ necessary in-house modification already done to it to accommodate the rear disc brake.
-CDI, Coil, rectifier, and 24mm carb
-3 piece engine mounts
-Rear disc brake hub
-Shock mount
-10x7 Dish wheel wrapped with Kenda K329 140/90/10 tire
-Stabilizer bar
-Stabilizer bar mount
-2 piston rear disc brake caliper
-rear stainless steel braided brake line
-Rear cross drilled rotor
-Carburetor bracket
-Aluminum intake arm
-Stainless steel hardwares
-Plug and Play harness
*requires use of 245mm or lower rear shock
Non-local interests, please email us for more information.
ATR Turbo Ruckus shown below with the mounts.
Yimmy built! Pick up a Jimmy up/down sticker toward the bottom of the post!
Wakura Anodized key handle
orange anodize SOLD OUT!
blue anodize SOLD OUT!
silver anodize
purple anodize SOLD OUT!
red anodize
gold anodize SOLD OUT!
Wakura mini key handle
black SOLD OUT!
silver
Wakura Oil filler cap w/ key lock
Will fit GY6 and Stock 50cc engine
black anodize
silver anodize
Koso 3 pcs. 12mm Axle puller
RPM oil dip stick
-fits both Honda 50cc motors and GY6
Standard Functions Edition ATR 50cc extension kit: Limited Edition
Gold anodize
Red anodize SOLD OUT!
-std fnctns X Bowls
Piano Black (Available at [url]http://www.bowlsla.com/store/pc/viewPrd.asp?idcategory=44&idproduct=8471]BOWLS[/url])
Stage 6 throttle set with left controls
Note: The included throttle cable will only work with slide type carburetor.
Special note!For those that are interested in the Stage 6 thottle assembly and left control; but don't run a slide carb... we have custom made throttle cables that will work with your stock carb. Email us for pricing on those cables. It will work with stock 24mm GY6 carbs as well and it's extended with a slack adjuster to better fit your set up. You will also receive the original Stage 6 slide carb cable, just incase you're going to switch to a slide carb later on down the road.
-black
-chrome
-steel gray
Stage 6 non offset kickstart lever
Zuma 50/Ruckus/Minarelli
-silver
-steel gray
Complete with
-extended throttle cable
-extended fuel line
-extended rear drum brake line
-rear shock mount
ATR carbon battery boxes
black-
red-
yellow
ATR Gas tank cover
black carbon
yellow carbon
red carbon
silver carbon
-Fiberglass, primer'd and ready to paint
ATR CF double sided luggage cover
black-
yellow-
red-
silver
ATR seat frames
Lowered 80mm
Front grocery bag hook
Shorten rear riser/tail
black-white
Stainless steel braided disc brake lines
Each line has clear silicone protective tubing
Each line includes 2 banjo bolts and 4 crush washers.
-front 46" long
-rear 94" long
"Jimmy" stickers 3.5X12cm
-Jimmy up (Safety First)
-Jimmy down (Safety Second)
If you have any questions about the products, please feel free to contact us at
standardfunction@gmail.com as our message box is flooded with other Pm's.
Local pick up is very welcome! Prices does not include shipping unless stated and only applies to the
lower 48 states.
Prices are subject to changes with out notice. Parts are sold for racing or off-road use.Thanks!
