 Post subject: Need some misc stock and aftermarket Ruckus parts!
PostPosted: Tue Feb 21, 2017 8:31 am
Looking for a few parts for my ruckus projects! Any help would be greatly appreciated!
Stock parts:
ignition surround - Pretty straightforward
Speedometer cable
Maybe whole speedo? My hot water temp light pulled out, and wont sit back flush in the gauge spot. Is this repairable?
Turn signal slide switch. Quite honestly, I just need the piece that slides back and forth. I can use a screwdriver to get the indicator to work, but the slide part broke off flush, so I could epoxy something on if they have a non working switch and can sacrifice the plastic bit!
My fuel cap wont unlock, so it makes it difficult to get it to seat in the gas tank as its "locked" but wont actuate to unlock. I don't think it's necessary seating fully.
Aftermarket parts:
I need a brake fluid reservoir cap for aftermarket brake kit. Somehow, my bike has a hydro disk brake for the front, but the screw on reservoir cap is gone. I have the gasket, just not the lid.
Tag style brake light. Old one apparently died a firey death as evidenced by the burned license plate. No brake light at the moment!
GY6 harness, or fusepanel. I have a Gy6 converted project that is all wired directly with no fuse box. I need to fix it so if there is at issue in the future, fuses will blow instead of fires occurring.
Spark plugs - Anyone have some proper GY6 plugs laying around?
Thanks in advance for the assistance. PM me prices or what you have and I'll message you back asap!
 Post subject: Re: Need some misc stock and aftermarket Ruckus parts!
PostPosted: Tue Feb 21, 2017 11:44 am
I can get you part of the way, I have a stock black ignition cylinder cover and a speedo off a 2015 ruck with 678 miles on it with cable, I also have speedo cable for ncy disk brake if that's your setup. If you want pics let me know. Say $25 plus shipping for the cover, speedo, and both cables.
BuildPlaything
PostPosted: Tue Feb 21, 2017 12:12 pm
Just sent a pm. I don't need a cable with the disk brake kit, that's another bike. I am still looking for a brake reservoir cover. We can work out details on the other.
Thanks!
