 Post subject: Fuel Delivery Problem
PostPosted: Mon Jun 18, 2012 6:10 pm
So my Ruck isn't running....
I have air bubbles coming out of my fuel pump. I have clear fuel line, so I can see had and air bubbles coming out the pump.
I've changed fuel pumps and installed new fuel filter. Still there.
Bike starts and a bubble near the fuel pump begins to form. Bubble grows and grows until there is no fuel in the line and of course it dies.
My last thought is maybe the small lenghts of fuel line from tank to filter and filter to pump is clogged or damaged.
Anyone have this problem before?
My Build: http://totalruckus.com/phpBB3/viewtopic.php?f=95&t=19287&start=0
"I play heavy strings, tune low, play hard, and floor it. That's technical talk." --SRV
 Post subject: Re: Fuel Delivery Problem
PostPosted: Mon Jun 18, 2012 6:21 pm
bad pump, i just went through this recently
MY OLD 40K MILE RUCK
MY JANKY NEW BUILD
PostPosted: Mon Jun 18, 2012 6:23 pm
I would agree bad pump
Thanks Honda GET going
My 2005 :LR:
Total Ruckus Super Scooter Search Of Massive Results
PostPosted: Mon Jun 18, 2012 6:41 pm
I replaced the fuel pump with a used one that a respected member sent me over a year ago. Both pumps do the same exact thing.
One more piece of information, my bike wouldn't even start until I removed the check valve. Now it starts like described earlier. No check valve now. Both pumps pitting air in the fuel line.
I can see air bubbles in the fluxing in the clear battlescooter fuel filter. Wtf?????
PostPosted: Mon Jun 18, 2012 6:48 pm
the oem fuel pump goes bad when it sits dry, i went through 3 used ones before i got 1 that finally works, all worked when pulled
if this ever happens to me again im buying a new OEM pump
MY JANKY NEW BUILD
PostPosted: Mon Jun 18, 2012 8:56 pm
Got the same thing goin on with my met, installed clear fuel line to replace a suspect oem line and lots of bubbles. ordered my new pump today.
2003 stella
2008 buddy 125
'84 Honda aero 125 x2
Honda metro's 2002 and 2006
PostPosted: Tue Jun 19, 2012 11:33 am
How is your fuel line routed did you change it's position from the
Factory setup. I think the hose routing is important..
My 2005 :LR:
PostPosted: Tue Jun 19, 2012 11:51 am
Check you fuel line.
I recently had a crack form in my fuel line right after pump.
Is fuel dripping at all?
Rusty 2003 Ruckus - "Ethyl Lynn" ~17,000 mi
PostPosted: Tue Jun 19, 2012 6:31 pm
It's not dripping, but it might be my problem...
Cause I got sure bubbles somehow in my fuel filter and air bubbles blowing out my fuel pump into the fuel line. Hmmmmm........
PostPosted: Sun Jun 24, 2012 8:30 am
Problem resolved yet?
Been dealing with similar issues on a known working pump, turned out to be a priming issue. The stock pump can be finicky if there is any air in the line or inside the pump. Do you have a clear line going from the tank to the pump as well? Can you confirm that there is no air in the line between the tank and pump? Including inside of the filter.
PostPosted: Tue Jul 24, 2012 5:24 pm
Replaced the fuel pump and no more bubbles on mine.
2003 stella
2008 buddy 125
