Post new topic Reply to topic  [ 28 posts ]  Go to page Previous  1, 2
 Post subject: Re: Ruckus popping downhill WOT
PostPosted: Tue Apr 10, 2012 8:35 am
^Gotcha! That's why I finally tried rejetting the other day. But the noise happened before and after rejetting. Still probably need to do some more jetting and definitely get a new spark plug
Junk Ruckus: viewtopic.php?f=94&t=66879
Ruck Fink Stickers: viewtopic.php?f=47&t=91889
PostPosted: Tue May 08, 2012 9:54 pm
i have an 09 with a posh cdi that i put in from battle scooter. i installed it with the help of a mechanic about 2 years ago. my electric start still works. ever since i installed it, it has worked, i.e. it goes over 38, 52 mph on gps. i also have an aftermarket exhaust and know what the rev limiter sounded like. i ordered the unlimited rev posh cdi from battle scooter store. when i get above 45 mph it sounds like a errrrrrrrr.rrrrr.ptptttpptpttttt. eerrrrrrr.ppttptptpttpt. its an electrical noise/rattle coming from the cdi in the battery box. it almost seems like there is a rev limiter on the posh.(i know they sold a 10K rev limited one) maybe there was a mix up. i haven't had any issues with it just a little annoying when your trying to haul ass tucked next to the battery box with the noise. from what i have heard the feedback from posh is almost non existent and battle scooter doesn't sell them in single quantities anymore. issues like this might have something to do with it. this just sounds like the same issue so i wanted to throw in my 2 pennies.
PostPosted: Tue May 08, 2012 10:17 pm
hes running a cdi mostly likely valve float shave the driveface to get the belt higher up on the variator .
http://i112.photobucket.com/albums/n188 ... kus033.jpg
PostPosted: Wed May 09, 2012 7:55 pm
anyone ever heard of the issue i posted?
PostPosted: Fri Aug 31, 2012 7:52 am
Bringing this thread back... Mine just started doing this. I have KN variator, Posh cdi unlimited, and blue launch springs. Those are the only performance mods I have. When I get up to 41.8mph it starts "shuffling metal cards". Is this the cdi? Or can I tune away from the noise? Do you think taking the cdi off will help? I've taken it off before, but there is a huge difference in all around performance, so I'd like to keep the cdi on. This happens on flats. So it is very annoying! No WOT for me :cry:
Bonnie the Zuma
http://totalruckus.com/phpBB3/viewtopic.php?f=95&t=84667
Rufus the Ruckus
http://totalruckus.com/phpBB3/viewtopic.php?f=95&t=65104
Buyer/Seller Feedback
http://totalruckus.com/phpBB3/viewtopic.php?f=86&t=72217
Ghosts
Ghosts
PostPosted: Fri Aug 31, 2012 8:57 am
what weights are you running? i run KN variator.. now that i have ncy cdi.. i only hear what you describe when im super high in the RPM range.. i believe it is the valves floating.. i basically back it down some.. however i am running 5g weights for faster acceleration and keeping speed on hills up here.. when i goto a flat area i change weights and p;ut heavier ones in.. i want to get a tach so i can monitor the RPMs but i know im way past the stock limit for sure.. doing 54 downhill and i hear it heh
me: 2009 Translucent Blue Ruckus aka Project Stitch 626
new addition: 2014 Honda GROM - TDM Blue
wife: 2009 Blue/White Metropolitan - SOLD 2013
Hobbies ==>Youtube - Photography <==
PostPosted: Fri Aug 31, 2012 11:31 am
Right now I'm running 5g/5.5g combo. I might try all 6g's and see if that helps. I'll report back when I switch them out
Bonnie the Zuma
Rufus the Ruckus
Ghosts
Ghosts
PostPosted: Fri Aug 31, 2012 2:15 pm
PostPosted: Fri Aug 31, 2012 3:48 pm
I'll have to order some 6g's. Forgot my brother has mine :headbashing:
Bonnie the Zuma
Rufus the Ruckus
PostPosted: Wed Sep 12, 2012 8:18 pm
Just put the 6 g's in and now it starts "shuffling" at 43mph. So a little improvement.. Thanks for helping! Probably will up the weights a little bit more
Bonnie the Zuma
Rufus the Ruckus
PostPosted: Wed Apr 12, 2017 6:03 pm
I have the same problem. Did it help with higher weights?? I know I have valve float
-posh cdi
-polini variator
-yoshimura
-1 in header
-PC20 carb 38/92
-needle clip in lowest position
-high rise cam
-uni foam filter
PostPosted: Wed Apr 12, 2017 6:21 pm
5 years later?
PostPosted: Wed Apr 12, 2017 6:27 pm
Well I shearched valve float. Sorry I'm so late but how did you fix it. I ordered heavier weights
-posh cdi
-polini variator
-yoshimura
-1 in header
-PC20 carb 38/92
-high rise cam
-uni foam filter
