 Post subject: 2004 nps50 ruckus surging idle
PostPosted: Mon Mar 28, 2011 2:32 pm
2004 nps50 Ruckus surging idle
Initially the fuel pump was bad, replaced it. now it runs but the idle surges up and down until it eventually stalls out.
I cleaned the carb 2 times to verify all circuits were clean....spic and span clean
I also installed a new tps and did the reset...still surging
then I played with the air/fuel adjustment...the surging is still there but not as pronounced.
How is this fixed? anybody else have this problem?
Does anyone have a better jetting set up that works on a stock Ruckus?
 Post subject: Re: 2004 nps50 ruckus surging idle
PostPosted: Tue Mar 29, 2011 12:31 pm
Anybody?
48hours of Ruckus Winner
PostPosted: Tue Mar 29, 2011 12:43 pm
Does it ever idle? Like after 5 or 10 minutes of neighborhood riding?
I, uncle ruckus, wrote:
39,438 total miles Rucked.
mine viewtopic.php?f=96&t=31836
PostPosted: Tue Mar 29, 2011 3:28 pm
It runs smooth, it's just that the idle goes up and down, a continuous pattern. Every now and then it goes low enough to stall itself out.
I replaced the tps thinking it was that, no change,now I just ordered the auto bystarter.
PostPosted: Tue Mar 29, 2011 3:32 pm
My '03 has been doing this. It sat for a couple years, so I just think it's dirty. At a stop the throttle surges a little bit, sometimes it just idles a little fast. All cables seem to be ok- just idles weird. I havent really looked into it yet.
RUCKUS DAY- April 15th!!!
viewtopic.php?f=95&t=99
PostPosted: Wed Mar 30, 2011 8:22 pm
Has anyone else had a surging idle caused by a bad auto bystarter?
PostPosted: Thu Apr 07, 2011 7:54 am
Replaced the auto bystarter and it runs perfect!
PostPosted: Thu Apr 07, 2011 8:18 am
PostPosted: Fri Apr 08, 2011 12:36 pm
uncle ruckus wrote:
Exactly :banger: :banger: :banger: :banger: :banger: :banger: :banger:
PostPosted: Wed Nov 28, 2012 5:12 pm
Kind of resurecting this but..
Would cold weather affect the bystarter? It's getting cold in Michigan and I get surging idle and sometimes it drops to like 1920-2000 after i let go off throttle and roll up to a red light/stop, other times it stays at 3k. Not sure what's going on :/
Rucksters browsing this forum: Exabot in disguise[Bot] and 2 guests
