 Post subject: Ruckus exhaust nut size
PostPosted: Wed May 05, 2010 7:16 am
It looks like one of the nuts fell off my exhaust. I was wondering if anyone knew what the size and thread pitch the nut is so I can pick up a replacement.
Thanks!
 Post subject: Re: Ruckus exhaust nut size
PostPosted: Wed May 05, 2010 7:19 am
Image[/quote]
left or the right?
I'm sorry, I actually don't know. Do you have a manual?
PostPosted: Wed May 05, 2010 7:27 am
nope no manual unfortunately.
i do have a spare set, but they are stuck onto the studs, I didn't realize they were studs and nuts till the nut fell off the exhaust. I guess I didn't tighten them enough.
PostPosted: Wed May 05, 2010 7:45 am
brb-i'll take a look for you.
PostPosted: Wed May 05, 2010 7:46 am
I didnt see anything in the manual so I guess your best bet would be to take to other off and take it to the hardware store. if you pm me your email address I'll send you a present :mrgreen:
My GY6 Met Build Yoshi
PostPosted: Wed May 05, 2010 7:51 am
you've got pm! thansk!
i'll swing by ace tonight and see if i can find the right nut.
PostPosted: Wed May 05, 2010 8:27 am
yep, the manual has an exhaust removal but it doesn't mention the pitch size. i even looked in the specs part but i couldn't find it.
i just read you only lost one so yes, go to ace with the other one.
PostPosted: Thu May 06, 2010 7:56 am
in case anyone else needs to know, its a m6 .8 pitch
PostPosted: Thu May 06, 2010 12:06 pm
If I am not mistaken it should be 6mm x 1.0 threads. Normally the only thing Honda will use in a 0.8 thread is a 5mm.
JC Racing
http://www.jcracingonline.com
My Ride
PostPosted: Thu May 06, 2010 1:21 pm
it said .8 on the box at ace, maybe i read it wrong, i'll double check.
