 Post subject: New guy Bogging down.
PostPosted: Wed Aug 02, 2017 11:08 am
2005 NPS50 replaced fuel pump about a year ago, haven't had time to play with it.
Starts and idles a bit fast till you touch the brake then idles down.
As soon as you start to accelerate it Boggs down.
What can I look for or do.
 Post subject: Re: New guy Bogging down.
PostPosted: Wed Aug 02, 2017 12:11 pm
Check for an air leak on the intake boot.
PostPosted: Wed Aug 02, 2017 2:04 pm
Intake boot looks good.
PostPosted: Wed Aug 02, 2017 2:29 pm
Start it up. Spray carb cleaner/wd40 near the boot. If engine changes speed, it's and air leak.
Bogging can be a sign of a plugged gas filter.
PostPosted: Wed Aug 02, 2017 2:46 pm
yeah. what happy said. Fuel filters are usually in-stock parts at dealers and I think they even have honda equivalents at auto parts stores, in the powersports section (ATV's, Jetski's, etc).
if doesn't take much of an air leak to cause a problem.
tip: make sure it's on it's center stand and/or that wheel is off the ground before you go spraying. Wroom!
Also use the little straw sprayer thing on the can. If the spray goes into the air filter it'll give you a false positive.
PostPosted: Wed Aug 02, 2017 3:33 pm
clean the carb.
check air filter.
