 Post subject: I have valve float help!!!!!!!
PostPosted: Wed Apr 12, 2017 6:30 pm
I have valve float at 45mph but I can push threw it and get 48. What should I do to get the most out of my little buddy
-posh cdi
-polini variator
-yoshimura
-1 in header
-PC20 carb 38/92
-needle clip in lowest position
-high rise cam
-uni foam filter
 Post subject: Re: I have valve float help!!!!!!!
PostPosted: Wed Apr 12, 2017 11:32 pm
@what rpm's do you experience the valve float?
most likely you are hearing / feeling / sensing the stock rev limiter......
do you have a cdi to raise rpm's past 10500 rpm?
Click This For My Ride !
rrpotd
:vondutch: :wavehello
P-Dub wrote:
.......daaaayaaaaaammmm.....
PostPosted: Thu Apr 13, 2017 4:42 pm
I have a posh cdi? Could the cdi be making the noise that what I thought it was at first?
-posh cdi
-polini variator
-yoshimura
-1 in header
-PC20 carb 38/92
-high rise cam
-uni foam filter
PostPosted: Thu Apr 13, 2017 5:25 pm
Just went ride not the cdi
-posh cdi
-polini variator
-yoshimura
-1 in header
-PC20 carb 38/92
-high rise cam
-uni foam filter
PostPosted: Fri Apr 14, 2017 3:21 am
How you checked valve lash?
Do you have a tach to see what rpm it's floating at?
Are the mods in your sig on this ruck?
-Ruckus
-Big Ruckus
-Grom
PostPosted: Tue Apr 18, 2017 8:18 am
I have new shims at correct gap. No tac no idea what rpm.
-posh cdi
-polini variator
-yoshimura
-1 in header
-PC20 carb 38/92
-high rise cam
-uni foam filter
PostPosted: Tue Apr 25, 2017 7:44 pm
Time to get one...
