 Post subject: My ruckus is moody
PostPosted: Sat Mar 04, 2017 6:41 pm
Specs :
2012
Pod filter
35/80 jetting
BR muffler
Ncy cdi
Polini variator
5g sliders
220lb rider
This combo seemed to work pretty decent with a new gates belt after a couple miles of break in. I didn't feel the 0-15 acceleration was as good as the polini belt I removed but it pulled to top mph 44-45 faster.
A day or so later a few degrees warmer the acceleration is worst , the top end is down to 41-42 (even limited to 46 downhill bombing)
I went back and changed to my 6g rollers - didn't help
Polini belt - didn't help
Cleaned the carb - didn't help
Made sure it had plenty of fuel and the pump is working.
It doesn't seem to shift out to the higher gear it did before.
I have a tach ordered and was supposed to come in today so I was tuning by "ear"
I did notice the clutch pads are glazed some ..... could this be the culprit ?
I didn't check the valve specs due to being hot but can do that tomorrow ....
What do the Ruckus guru's say ?
What's wrong with my moody gal ?
 Post subject: Re: My ruckus is moody
PostPosted: Sun Mar 05, 2017 1:53 am
Tire pressure?
When i used to lose a couple mph, it was always something small like that.
