Post new topic Reply to topic  [ 1 post ]
 Post subject: Wiring: Right Side Controls - HELP OBI!
PostPosted: Fri Feb 03, 2017 7:13 pm
Ok, wiring up my Spree harness to my Ruck Controls. I thought I had it right but please correct me if I am wrong OBI :headbashing:
11' Ruckus:
Green/Yellow: Brake Switch
Yellow/Green: to ECU (Says CDI on the diagram)
Black/Red: to ECU (Says Battery, on the controls its to "OFF" switch up)
Black/White: to ECU (Says Co... can't really read it but on the switch its to "RUN" switch down)
87' Spree:
Yellow/Red: Starter Button (To Starter Relay)
Green: Ground (Grounds the Starter button and grounds the "OFF" switch in both positions (sprees have kill up and down, RUN is in the middle))
Black/White: Ignition/CDI (on the controls is to "RUN" switch middle)
Spree doesn't use Brake switch recognition. What do i need to do to bypass the "brake switch engaged, OK to start". Ruckus brake switch goes to all kindsofshit. and i don't need it....
I thought i had it right by wiring up the same as i saw on each controls. The caveat was that the Ruckus GROUND TO KILL is Black/Red and the Spree GROUND TO KILL is Green...
Looking for a simple solution. Any assistance it greatly appreciated.
