Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
 Post subject: Re: Symptoms of a bad (or incorrectly installed) CDI
PostPosted: Thu Jan 19, 2017 6:46 am
check wiring
PostPosted: Thu Jan 19, 2017 8:11 am
I checked the pictures you posted vs the CDI install and it looks correct (since you switched the yellow and orange wires). What I would do is uninstall the whole thing and make sure the bike runs again without the CDI then go back and do the install again. But from where I am sitting it looks like it is correct. Did you buy it new or used by chance?
Build Thread: viewtopic.php?f=93&t=106626
PostPosted: Fri Jan 20, 2017 6:47 am
I bought it new, but a few years ago. I hadn't gotten around to hooking it up until now, hopefully having it sit didn't do anything.
The Shadow Cycle
PostPosted: Fri Jan 20, 2017 6:55 am
I got an NCY that has never been used, sitting in my garage. I got it at the end of '15. I used another CDI. I looked and I know I have the red box, can't say about all the wiring. If you think it's the CDI, pm me.
PostPosted: Fri Jan 20, 2017 7:33 am
I'm going to do as jordandenmark1 suggested and redo the wiring. I'm also going to replace the battery as also suggested. If I'm still having issues I'll shoot you a pm.
The Shadow Cycle
PostPosted: Sat Jan 21, 2017 5:02 pm
Decent improvement. I decided to redo the power tap to the black and white wire (wasn't exactly sure where to do it so I just did it at the ecu near where the orange and yellow wires go in) and it would turn over with a kick start. Kill switch would also work. I still have no power and therefore cannot turn it over electrically. Next step is a new battery. Thanks guys for all your help.
The Shadow Cycle
PostPosted: Tue Jan 24, 2017 12:53 pm
Glad it worked! let us know what happens when you get the new battery
