 Post subject: Interchangeable ECUs
PostPosted: Thu Jan 05, 2017 11:53 am
I have an 03 ruckus I am waiting for it to die then swap an 06+ engine in it. I found an ECU online used Part Number GEZ-612 and figured I would get it since I'll need it eventually anyway and maybe squeak out a few MPH for a while. I plugged it up and I got nothing! Tried an ECU reset and got nothing. I plugged it into an 07 and got nothing again.
Am I missing something or is this thing just an expensive paper weight now???
Build Thread: viewtopic.php?f=93&t=106626
 Post subject: Re: Interchangeable ECUs
PostPosted: Wed Jan 18, 2017 11:10 am
bump for any ideas?
PostPosted: Wed Jan 18, 2017 4:26 pm
You may have bought a bad ECU. I've used a 612 and 611 on older motors (06 -07)but I've never tried it on a pre 06 harness.
2011 Ruckus
PostPosted: Wed Jan 18, 2017 5:01 pm
yikes. Is there any way to test it?
PostPosted: Wed Jan 18, 2017 5:14 pm
Just wondering, when you tried to start it did your ruck blow a fuse?
But yeah, it might be a bad ECU you bought.
Sounds like you already tested it. You put it in the 03 & 07 and nothing happened, right? :meh:
PostPosted: Wed Jan 18, 2017 5:53 pm
I dont think it blew a fise because I put my stock one back on and everything worked fine so IDK. I tried it in both bikes and got nothing.
