Post new topic Reply to topic  [ 17 posts ]  Go to page Previous  1, 2
 Post subject: Re: re-Inserting the engine bushings
PostPosted: Sat Apr 15, 2017 5:17 pm
thanks I'm going to give it a shot this afternoon. bought a 6" 3/8ths today with washers and nut. I emailed steady last week, their reply was to cut the stabilizer bar 10mm. Im unsure about that, since anything can be fudged when it comes to cutting. How has moving the bushing held up on your end, Lilpinny?
PostPosted: Sun Apr 16, 2017 8:52 am
I've never had any problems with it. Solid as a rock and I'm 260lbs.
The thing I messed up on when I was doing it is that I actually removed one of the bushings. You don't have to take them out at all, just move the right one a little bit. I just made more work for myself.
You should be able to put the spacer that came with the mount on top of the left bushing where the base of it is flush with the frame and that little nipple part on top is the only thing sticking out a little. You shouldn't have to move that bushing, or if you do, just a little bit. Then you get that cross member in there and you can see how far you have to move the right bushing out. It might take a couple of tries since you might overshoot it a couple of times. But that whole mechanism is a solid three point connection.
