Troll
Troll
 Post subject: GY6 Clutch Spring Install
PostPosted: Sun Sep 05, 2010 6:31 pm
I don't think there is a How To for this on the GY6, so here it goes.
This is for installation of the torque spring and 3 clutch springs using an impact wrench (manly tool) and a rubber strap wrench.
Step 1: Remove the variator cover
Step 2: Using an impact wrench, remove the nut holding the variator, and the nut holding the clutch.
Remove the variator, clutch, and belt.
Step 3: Slide the clutch bell off, and clamp the nut on the clutch in a solid vice.
Step 4: Using a rubber strap wrench around the clutch, turn it counter-clockwise.
Be careful when you near the end of the threads, the tension of the spring will send the clutch flying off.
Step 5: Remove the 3 C-clips from the clutch, remove the plate
Step 6: Using an awl, or needle nose pliers, remove the 3 springs, and replace with new springs. Pay attention to their direction.
Step 7: Replace plate, C-clips, and re-assemble using new torque spring.
Compress the assembly using one hand, one foot, and use your other hand to start threading the nut.
Clamp the nut in the vice, and tighten the clutch with the strap wrench, same way you removed it.
The El Ruckuso Custom Forward Peg Mounts
The El Ruckuso
Project: MANIMAL
 Post subject: Re: GY6 Clutch Spring Install
PostPosted: Tue Sep 07, 2010 8:56 am
Thank you sir! Very useful :usa:
Likes Phở & SkewterZ
PostPosted: Tue Sep 07, 2010 5:18 pm
:banger: thanks there El Ruckuso. was going to be doing this in the near future and now i have a how to!
P.S. you need to add the pooch in the background to MANIMAL FTW!
- something clever goes here
viewtopic.php?f=92&t=45383
PostPosted: Wed Jan 11, 2012 8:07 pm
What size sockets are required??
The B.S.T. build thread
PostPosted: Thu Mar 08, 2012 11:26 pm
8mm for outer case, 17mm for variator and clutch, and 1 1/2" or 38mm for big clutch nut. Just did mine. Only took 30min.
My '11
http://totalruckus.com/phpBB3/viewtopic.php?f=93&t=64705
PostPosted: Sat Mar 10, 2012 7:06 pm
Instead of stepping on it to compress it. I went to Lowes and got a 2 finger Bessy clamp
It controls the compression using the screw handle letting you slowly release the pressure instead of having it hit you in the face.
Custom built gy6 frankenbuggy / urban assault vehicle
PostPosted: Thu May 24, 2012 12:47 pm
what kind of gains did you see after the spring upgrade?
ImSoNice Crew
my "build" thread
http://totalruckus.com/phpBB3/viewtopic.php?f=94&t=68705
PostPosted: Thu May 24, 2012 7:15 pm
About $16 bucks worth. A little harsher engagement at a little higher rpm. At least that is how I felt it was on my bike. I think if you are a light weight rider on a bike with big power and torque you might notice a bigger difference, but on a stock bike..not too much.
My '11
