Post new topic Reply to topic  [ 187 posts ]  Go to page 1, 2, 3, 4, 5 ... 13  Next
 Post subject: Speedo in the Battery Box (pj version)
PostPosted: Tue Oct 02, 2007 5:56 pm
Edit: When taking your speedometer off, follow the wires into the battery box and disconnect them from the wire harness by unplugging them. Do not try to pull the lights out of the speedometer. You may have to take off the front cover to do this.
Part 1:
So heres how I went about moving the speedo to the battery box. First using a caliper I measured the diameter of the speedometer to be 2.56 inches. Then using a compass I made a 2.56 inch circle on a piece of cardboard to use as my template for the hole to be made in the battery box. I then used a sharp knife to carefully mark the outline of the template onto the battery box.
Next I used a dremel tool with a drill bit to make a series of holes on the inside of the outline.
Then using the dremel with a sanding disc I cut between all the holes.
To smooth out the hole I used the dremel with the drum sanding attachment and my knife to clean up the edges. This is also where you make any small adjustments to the hole to make sure the speedo fits.
And here you have it, speedometer in the battery box.
To hold it in there all you need to use is a hose clamp.
Part 2:
Spacing out the ECU.
You may wonder, why would I need to space out the ECU, this is why. Its kinda in the way.
The following hardware is needed to move out the ECU:
(2) 5mm x 50mm bolts
(1) 6mm x 35mm bolt
(2) 36mm (or about 1.4 inch) spacers
(1) 19mm (or 0.75 inch) spacer
and misc. washers
The blue arrows in this picture point to the two 5mm bolts with the 36mm spacers and the red arrow points to the 6mm bolt with 19mm spacer.
Here you can see the ECU moved out.
And with the battery box back on you can see the ECU is now out of the way.
Putting the battery box back on with the speedo in is not an easy task, it a pretty tight fit.
And there you have it, thats how you put the speedometer in the battery box.
Anger is always the shortest distance to a mistake.
PostPosted: Tue Oct 02, 2007 6:23 pm
wow great idea to move out the ecu. i did the old "stick it in there" way... i like yours better :) Awesome!!
Click here to see my garage. sold
Click here to see my Ruckus in Progress. sold
PostPosted: Tue Oct 02, 2007 7:45 pm
Looks great, the only difference with mine is I used nylon spacers, I angled mine flat at the top as well, just my personal preference though. None the less nice work
PostPosted: Tue Oct 02, 2007 7:47 pm
Very nice write-up and method. This is one of the many cosmetic mods I'll be doing over the winter...so thanks.
PostPosted: Thu Oct 04, 2007 3:28 am
thanks for the write up...i might have to try this one
PostPosted: Thu Oct 04, 2007 10:25 pm
Yeah your way seems so much easier and less wire work. thanks
PostPosted: Fri Oct 05, 2007 7:47 am
Sweetness, thanks man. I wonder if theres enough clearance for a tach as well, or perhaps the other side. ill have to check it out.
 Post subject: Re: Speedo in the Battery Box (pj version)
PostPosted: Sun Oct 21, 2007 1:27 am
[quote="PuddleJumper"]Part 1:
[img]http://i73.photobucket.com/albums/i211/RuckRider/Ruckus%20Mods/sibb1.jpg[/img]
[img]http://i73.photobucket.com/albums/i211/RuckRider/Ruckus%20Mods/sibb2.jpg[/img]
[img]http://i73.photobucket.com/albums/i211/RuckRider/Ruckus%20Mods/sibb3.jpg[/img]
[img]http://i73.photobucket.com/albums/i211/RuckRider/Ruckus%20Mods/sibb4.jpg[/img]
[img]http://i73.photobucket.com/albums/i211/RuckRider/Ruckus%20Mods/sibb5.jpg[/img]
[img]http://i73.photobucket.com/albums/i211/RuckRider/Ruckus%20Mods/sibb6.jpg[/img]
[img]http://i73.photobucket.com/albums/i211/RuckRider/Ruckus%20Mods/SIBB7.jpg[/img]
Part 2:
[img]http://i73.photobucket.com/albums/i211/RuckRider/Ruckus%20Mods/sibb8.jpg[/img]
(1) 6mm x 35mm bolt
and misc. washers
[img]http://i73.photobucket.com/albums/i211/RuckRider/Ruckus%20Mods/sibb9.jpg[/img]
[img]http://i73.photobucket.com/albums/i211/RuckRider/Ruckus%20Mods/sibb10.jpg[/img]
Great How to do it! Pictures tells the story. Thanks
[img]http://i73.photobucket.com/albums/i211/RuckRider/Ruckus%20Mods/sibb10-5.jpg[/img]
[img]http://i73.photobucket.com/albums/i211/RuckRider/Ruckus%20Mods/sibb11.jpg[/img]
[img]http://i73.photobucket.com/albums/i211/RuckRider/Ruckus%20Mods/sibb12.jpg[/img]
And there you have it, thats how you put the speedometer in the battery box.[/quote] :)
PostPosted: Sun Oct 21, 2007 1:45 am
^ WTF was that? :D
PostPosted: Sun Oct 21, 2007 4:11 am
varroa wrote:
^ WTF was that? :D
He added a :) at the end. Took him 5 months to post a :) ?
Phishin wrote:
I stood up in church and called him out.....right in the middle of service. And sat back down and listened to the rest of his bull shit.
Build Thread: viewtopic.php?f=95&t=9731&hilit=thunder%27s+ruck
PostPosted: Sun Oct 21, 2007 6:47 am
PostPosted: Sun Oct 21, 2007 4:50 pm
ThunderstRuck wrote:
varroa wrote:
^ WTF was that? :D
he also added:
PostPosted: Sun Oct 21, 2007 9:52 pm
I just did this this afternoon. The ECU is just kind of hanging out in there (I spaced it out with one long bolt I had handy) but it's not going anywhere. I need to get a hose clamp to secute the speedo properly. It is a tight fit, but things worked out OK. I really am glad I decided to do this because with my handlebars (Pro Taper offroad bars) the speedo cable would bind up the steering when I turned to the right. No more binding and a lot cleaner looking now.
I laid down some masking tape on the battery box, traced a circle around the hole saw I was going to use (2.5"), cut the hole, and used a rounded file to enlarge it very slightly to 2.55". The speedo is a snug friction fit so I'm not worried about it moving until I can get a hose clamp on it.
I do wish the speedo cable were shorter! It looks dorky hanging so far off of the front.
PostPosted: Sun Oct 21, 2007 10:35 pm
You can get shorter cables through Southtek in the classifieds section.
He would order from Tokyo Parts and ship to your door!
bigluelok wrote:
PostPosted: Thu Oct 25, 2007 7:15 pm
Here's how mine turned out. Works great. Would love a shorter cable.
