Post new topic Reply to topic  [ 4 posts ]
Bathroom mechanic
 Post subject: Fuel filter replacement
PostPosted: Sun Jun 18, 2017 4:52 pm
I have looked and looked on here but cant find the thread that explains how to change the fuel filter. It has to be there but I cannot find it.
Thanks
Bathroom mechanic
 Post subject: Re: Fuel filter replacement
PostPosted: Sun Jun 18, 2017 6:41 pm
I also need instructions on how to install the leg shields if anyone has them
CANADIUS MAXIMUS
CANADIUS MAXIMUS
PostPosted: Mon Jun 19, 2017 7:28 am
I'm not sure if there IS a thread specifically for that , probably over-looked due to its simplicity.
I'll walk you thru this ,
1. Remove your left footrest
2. Remove the left side panel
3. The fuel filter and fuel pump are mounted right there on the side of the gas tank.
4. Gently use pliers to squeeze the fuel line clamps and pull the lines off the white fuel filter.
5. The fuel pump and the fuel filter are held on to a metal arm with black rubber mount, easily come off.
When you're finished , reverse those steps and you're done.
:canuck:
Stimpy433 wrote:
....If you don't get a refund then shit in a box and UPS it to him....
2005 BIGUS Ruckus
viewtopic.php?f=95&t=41664
....ya....thats right...."PS-600".....bite me
Bathroom mechanic
PostPosted: Wed Jun 21, 2017 7:45 am
Thanks Sawman
I appreciate the info
Judge Jim in SEOHIO
