 Post subject: Clutch Holding Tool Buzzetti 5637 (pic)
PostPosted: Fri May 30, 2014 11:17 am
Description
Buzzetti Flywheel and Clutch Pulley Holder Tool. Comes with 5mm and 9mm holder pins.
With the Clutch Positioning Tool in your hands, you can hold the clutch basket tight so you can loosen the bolt or tighten it back up.
Additionally, this tool can be used to open/ close the large bolt on the clutch.
I decide to buy clutch holding tool, so I can do simple maintenance by myself.
But I don`t want to buy a piece of junk.
Serfing Inet I found this - Buzzetti Tool 5637.
http://www.af1racing.com/
They didn`t have tool in stock, but said that they can order it. It takes 2-3 weeks and several days for shipping inside US.It can take more time. At the beginning seller said it can take 8 weeks.
The tool made in Taiwan( surprise :) ).
If you have any questions you can contact to steve@af1racing.com.
http://www.af1racing.com/store/scripts/ ... duct=61621 - order tool link
Buzzetti Tool 5637 - $22.99
Shipping : $8.95
Ship Method : USPS Priority Mail or UPS Ground
Order Total : $33.94
Payment Type : PayPal (+$2)
I paid using paypal, so I should pay additional charge. It`s possible to choose another payment method.
 Post subject: Re: Clutch Holding Tool Buzzetti 5637 (pic)
PostPosted: Sat May 31, 2014 1:49 am
I made mine out of half of a rear suspension from a mountain bike that a friend and I had found out in his junk pile.
It's an offset V shaped tubular piece of metal with two eyelets on the ends, which I stuck a couple of tempered bolts through.
I only had to bend the piece a tad to make the holes line up !
The simplest way though, is to just take a length of plywood and drill two corresponding holes through it to stick your bolts through.
Make the piece long enough on one side to make contact with the pavement.
The weight of the bike keeps it in place.
PostPosted: Mon Jun 16, 2014 9:36 pm
Same tool i've used for the little ruck hundreds of times, works for the big ruck, the handle braces against the centerstand
THE RHINO (BR)(TOTALED)
Heart Breaker(SOLD)
*AZ RUCKSTARS*
PostPosted: Thu Sep 11, 2014 4:31 pm
Here is one to change the belt. Use it to hold the flywheel. :lol: I have use it twice already :banger:
Like to learn TotalRuckus Style
Rucksters browsing this forum: Snakes and 2 guests
