 Post subject: Electric Starter - why won't you work?
PostPosted: Thu Jun 23, 2011 7:55 am
Hi Everyone,
I have a 2003 Ruckus and recently the electric starter stopped working. It's been a dreamboat of a bike up until now, although the kick start still works after a couple of goes. I had it tuned up this spring and they replaced the battery. A couple of weeks after that the starter stopped working. It click click clicks and then eventually stops. Took it back to the shop and they said probably one of the fuses was draining the battery. Has this happened to anyone out there? The mechanic said it would take him a while to test all the fuses individually and assess the problem but it's really bugging me and I'm prepared to sit down with a volt meter and get the job done if that's what it is.
Thanks in advance for your help guys.
Megan
48hours of Ruckus Winner
 Post subject: Re: Electric Starter - why won't you work?
PostPosted: Thu Jun 23, 2011 8:53 am
megcass wrote:
Hi Everyone,
Megan
Hi, megcass.
My starter has not worked consistently since I bought my Ruck. A new battery fixes it right up but the starter will eventually stop working...that leads me to believe that i have a slow power draw somewhere. I'm good with kicking it so I have never looked for the problem. Good luck!
I, uncle ruckus, wrote:
39,438 total miles Rucked.
mine viewtopic.php?f=96&t=31836
PostPosted: Thu Jun 23, 2011 11:25 am
x2 - im a kicker
My Build: Ma Deuce (50 Caliber)
viewtopic.php?f=93&t=49192
Trigger Coast Rollers
PostPosted: Thu Jun 23, 2011 11:36 am
It probably is the battery if you have not replaced it yet.
"Fort Insanity" Build Thread
rat42 wrote:
The first rule of ruckus racing: never tell the other guy you are racing.
PostPosted: Tue Jun 28, 2011 8:17 am
Thanks guys, it's not the battery - it's brand new. One of the electrical components is draining the battery even when the bike is turned off. Has anyone had this happen? Is there a common electrical problem I could look at?
PostPosted: Tue Jun 28, 2011 8:23 am
in for this too. New battery didnt fix my issue either. Neither did new engine or wiring harness would REALLY like my electric start back.
-unhappy member of the kickstart club
BUILDS
DD beater http://www.totalruckus.com/phpBB3/viewtopic.php?f=96&t=85294
background build http://www.totalruckus.com/phpBB3/viewtopic.php?f=96&t=87090
Skipbarber wrote:
PS: Ever notice that the more you spend on a ruckus, the less of it there seems to be?
PostPosted: Tue Jun 28, 2011 8:29 am
whats a kick starter?
MY OLD 40K MILE RUCK
MY JANKY NEW BUILD
PostPosted: Tue Jun 28, 2011 8:36 am
I ran without a start button for a long long time because I had spliced wires together without soldering them. Once I redid all of my harness splices with solder, it started working every time. Anecdotal, I know, but perhaps a loose connection you could check?
< My Ride >< Flickr >
PostPosted: Tue Jun 28, 2011 9:01 am
Put the battery charger to her and start tracing. New battery doesn't mean better. DVOM is your friend.
You say click click and then nothing. Is that the bendix engaging the starter clutch but not enough juice to turn the crankshaft? If so, that'd lead me to believe that the power flowing to/from the starter is insufficent. Provide extra leads and see if remedy.
My Zumas were plagued with this until I replaced the leads with large gauge wire, respectively, to the starter as teh amp draw was too great.
Next is this battery drain you explain. Gonna be going circuit by circuit until you find the errant draw. I prefer to disconnect the ground lead on the battery and place a test light in between the batt and this lead. If you have light, there's a draw. Start pulling out the fuses one by one until the light goes out.
'05 Yamaha Zuma 400 ---Onto greener pastures
'08 Yamaha Zuma 180cc
'00 Aprilia SR50
'99 Derbi Manhattan
'01 Suzuki SV650 ---Almost ready to ride
'80 Yamaha Champ LC50
'05 Honda Metropolitan ---The reliable commuter
PostPosted: Tue Jun 28, 2011 9:04 am
there is no starter or starter clutch on a GET :P
MY JANKY NEW BUILD
PostPosted: Tue Jun 28, 2011 9:21 am
Explain that to me then.
'00 Aprilia SR50
'99 Derbi Manhattan
The Official Unofficial TR Sheriff!!
PostPosted: Tue Jun 28, 2011 9:22 am
because the HONDA Ruckus has an osmosis style starter. it runs off a wireless harness.
My Ruckus: http://totalruckus.com/phpBB3/viewtopic.php?f=93&t=54160
- B.I.T.R.
The Bureau of Internal TRama
ruckus2009 wrote:
If he was some troll, I'd be with you- give him the boot. .
PostPosted: Tue Jun 28, 2011 9:25 am
Hmm. I thought it was telepathy type? When did they go to osmosis? Fuckers always a changin'.
Riddle me this then, where is the o/p getting an electric starter issue then?
'00 Aprilia SR50
'99 Derbi Manhattan
PostPosted: Tue Jun 28, 2011 10:06 am
yes he has an issue with the electric start, no there is no starter motor or clutch on a GET, it sends power back into the stator instead
MY JANKY NEW BUILD
PostPosted: Tue Jun 28, 2011 10:07 am
i have old motor has stator issue first starts runs ok then go for a ride then later got stator move back and forth having weak power then later got accidents from last year then i got brand new motor 09 anything brand new carb with wire setup and stator is pretty much brand new! when i installed whole new motor into my ruck and starting hooked up anything then i turn the key on then press stator button and hold rear brake lever stator is really strong turning first times! no issue for newer motor on my 2007 ruckus but one thing my battery is going stopped working becuase is older now i going get a special battery called odyssey high quility battery that stator will really turning very fast you gotta see anytime soon!
good luck for your ruckus!
CHEERS!!!!! :banger: :banger: :banger: :banger: :banger: :banger: :banger:
my rides
viewtopic.php?f=95&t=54864
my 2007 Honda ruckus is sold ! this is history for now now for 2016 Jan 7 bought new honda mets 2014 blue I still grand Rapids michigan
