Post new topic Reply to topic  [ 8 posts ]
 Post subject: Elite 250 Clutch Size
PostPosted: Thu Feb 26, 2015 10:53 pm
Can someone tell me the clutch size on the CH250? I have one I will be using for future swap and have an opportunity to try a decent aftermarket clutch but need size. :meh:
My Met Build
Cracka Jacked viewtopic.php?f=92&t=50500
"Never run out of real estate, traction and ideas at the same time." - Mario Andretti
 Post subject: Re: Elite 250 Clutch Size
PostPosted: Thu Mar 12, 2015 12:41 am
elite 250 tech tips look them up . Same thing as the the honda helix . the parts interchange for 85 to 89 I think .
PostPosted: Thu Mar 12, 2015 2:18 pm
Thanks fullmetalscooter!
My Met Build
Location: the land of cotton... old times here are not forgotten
Living room mechanic
PostPosted: Thu Mar 12, 2015 2:24 pm
Agreed, seems elite 250 parts same as helix 250 parts. I hear many parts from 250cc Chinese scoots fit as well.
the Ruckix
the Ruckus
60/49 club member
How to post pictures <- clicky
PostPosted: Thu Mar 12, 2015 3:38 pm
AVOID CHINESE PARTS AT ALL COST!!!
Case in Point...
Honda CH250 Starter Clutch = $88 bucks (Should last 17,000 sMILES)
Chinese Starter Clutch = $35... lasted me 500 miles!!! Fuck that shit!!!!
Oya Malossi CH250 clutch has a nice bite but did loose a couple mph on my top end.
DIDn't Mess with it that much... took it out when the clutch brace started to rattle.
-Honest™
PostPosted: Fri Mar 13, 2015 12:09 am
Honest Mike, 135mm????
My Met Build
CANADIUS MAXIMUS
CANADIUS MAXIMUS
PostPosted: Fri Mar 13, 2015 3:45 am
I'm not sure if the Elite had clutch issues , I would stay stock, spend a bit of time modifying the variator and driven pulley.
As for the motor , if you can't find the mods , make the mods... :wink:
I'm sure a simple rejet would be in order , and a free flow exhaust , all said and done , you would end up running "honda reliability" that will run top speed in the 80mph range.
For variator mods , machine the faces, play with the boss length , doing these two things can achieve a quicker take-off AND top-end , look into slightly lighter weights , look for the size needed but in Dr Pulley Sliders , check North West Buggies for you size , they have a ton of stuff for various machines
:canuck:
Stimpy433 wrote:
....If you don't get a refund then shit in a box and UPS it to him....
2005 BIGUS Ruckus
viewtopic.php?f=95&t=41664
....ya....thats right...."PS-600".....bite me
PostPosted: Fri Mar 13, 2015 8:53 am
Thanks Sawman! As much GET CVT tuning as I've done, it should be fun. Endine doesn't go in until next fall/winter. Just accumulating parts now.
My Met Build
