 Post subject: Fugly Reflectors !
PostPosted: Thu Oct 22, 2015 8:54 am
I don't know how many here have removed that horrible rear reflector bar, but I just did and the lines of the bike look much nicer.
There's a removable plastic blank below the license plate mount that accepts one of the 4 rear reflectors perfectly !
(you have to drill two new holes for the plate to mount to)
That covers your legal status for the rear of the bike.
I then took two more reflectors off the bar, drilled a small hole on each side of the plastic fender and mounted them facing down the long way.
The bike looks 100% better !
Next, I'm going to find a couple smaller size amber reflectors and replace the stock front ones with theose.
 Post subject: Re: Fugly Reflectors !
PostPosted: Thu Oct 22, 2015 9:28 am
I did the same, tho my rear reflector is also an LED brake light (not used as a running light, just a brake light) i plan on changing the front yellow reflectors to be running lights and additional turn signals.... :highfive:
'05 Zuma Athena 70cc:
viewtopic.php?f=93&t=88015
'08 Morphous:
viewtopic.php?f=93&t=88013
