 Post subject: I think i may have a short
PostPosted: Tue Mar 22, 2016 4:23 am
Ok so i relocated my licence plate and hooked up some licence plate lights the ruckus started up fine then i added some leds under my seat it used to run fine with them but all of a suddened started idling at about 3000 rpms and now it wont start unless i kick start it and my blinkers dont work any more maybe i blew a relay??? Help its my daily i hooked everything up to the black and brown wire in the rear
 Post subject: Re: I think i may have a short
PostPosted: Tue Mar 22, 2016 7:07 am
Did you check the fuses?
Did you install an electronic flasher when you added LEDs? (wouldn't make the Ruck act as you describe, but you need one if you add in LEDs)
