Post new topic Reply to topic  [ 1 post ]
 Post subject: Switched power shorting out
PostPosted: Tue Dec 01, 2015 10:01 am
So, I am working on a stock Ruck. With the key off I am getting my 12v to the red/blue stripe (as I should) BUT, turn the key, voltage dumps (goes to like.47v) on both red/blue stripe in and the red/green stripe out. NOW, if I have the key off (or out) and put the leads on my multi-meter to the POSITIVE on the battery and to the red/green stripe, I show 12v again indicating a ground short. fuses are good, relays in tact and no visible wire shorts. If I disconnect the brain box I have proper continuity on each wire and the red/green stripe is not sharing a reading with any of the grounds (frame, green wires, battery terminal). My question for you seasoned pros is; does this sound like the CPU is trash or am I overlooking something? I am a shop owner, I do lots of work on these little guys and I have experience with most makes and models of two wheeled machines. I am scratching my head trying to come up with another solution aside from this poor guy needing to replace the computer. If anyone has encountered something like this before, I would love some help and I will return the favor when I can.
Cheers
You boys drinkin on my land? You motocrossers ain't too bright, Ill show you boys how to get down this hill..........
Last bumped by BPScootin on Tue Dec 01, 2015 10:01 am.
