 Post subject: Problems with starter solenoid
PostPosted: Fri Oct 02, 2015 9:09 am
I need a little help on a bike. I just got done building a ruck and having some electric issues with a makoa harness. The fuse above the blue starter relay keeps popping and then the starter solenoid would get so hot it would start to smoke. This only happens when we start riding for 15 mins or more. The solenoid has been replaced multiple times with a new one. Thanks in advance
 Post subject: Re: Problems with starter solenoid
PostPosted: Fri Oct 02, 2015 10:06 am
im guessing this is a gy6 if your starter solenoid is getting hot while riding it is not disengaging after the motor starts
My ruck "build"
The Asphalt Slayer
T.sracing wrote:
