 Post subject: Replace ecu now cdi don't work
PostPosted: Tue Sep 15, 2015 3:40 pm
Ok guys I have an 06 ruck modded out pretty good my ecu fried on it so I found a used 09 ecu with 875 miles on it my ruck has alittle over 16000 miles on it when I installed the new ecu my rev limiter came back I have a kitaco cdi question is did my old ecu fry my cdi box I already reset the new ecu and the rev limiter is still there so any comments would be helpful thanks
 Post subject: Re: Replace ecu now cdi don't work
PostPosted: Tue Sep 15, 2015 6:18 pm
How do you know the ecu was fried?
TT-350z wrote:
Build Thread
PostPosted: Tue Sep 15, 2015 6:34 pm
Went through 15 10amp fuses every time I would turn key to on position it would fry the 10 amp fuse so I bought a used ecu and now that doesn't happen anymore no problems now except the rev limiter and it sucks cause I can only get 3/4 trottle then bang rev limiter
PostPosted: Tue Sep 15, 2015 7:10 pm
What rpm?
the Ruckix
the Ruckus
60/49 club member
PostPosted: Tue Sep 15, 2015 7:17 pm
The cdi was a kitaco hybrid no limit but it only revs to 8890 now with it hooked up and it use to Rev I'm pretty sure to 11500
