 Post subject: Ruck On Fire, Help!
PostPosted: Sun Sep 13, 2015 4:47 pm
Well this day just went and took a big ol dump on me. Got my new throttle cable and rear break cable in and finished fabing a mount for my overflow bottle. Got it all installed and go to turn the key over. Fuel pump kicks on (had to pull the fuel line, it was kinking bad, so added a slightly longer hose between the filter and pump). Push the start button, nothing.
Oh hey, dummy, didnt plug the wires back into the front break for the safety start switch. Push the start button, cranking, cranking, not really catching. Then it stops, low fuel light kicks on. Well i got my boat anchor down, kick it off that down level, press start, nothing.
Then i smell something.... Something burning, smoke is trailing out of my batt box at the neck. I make the mad dash for the screw driver, dragging the ruck with with me, because putting the kickstand down wasnt on my mind apparently, zip those screws off the batt box, there before me it looks like the smoke is coming from around the computer. It is the computer, oh shit!!!
I pull the top wire harness bundle connector off the computer and it stops trying to burn itself at the stake.
Disconnected the computer entirely and looked it over. A small pinpoint spot just below that main connector on the backside the black plastic is melted a bit. I plug it back in, no key in. And that same spot begins to heat up, disconnect the main wire bundle and it stops.
Any idea why this happened? The electrical ive done on the bike is:
New battery
Reroute some wires to free up some more space in the batt box (just unplugged them and moved them behind some of the bracket work and re plugged them)
Thats it.
I did have to charge the battery today because it went stone dead after sitting for the week, while i was waiting for parts, which i thought odd. Is this just a suicidal computer or is there something else going on?
The plug on the bottom of the computer is the input point for the power correct? So why is unpluging the top wire plug stopping it from getting hot?
Either way it looks like i need a new computer, dont want to fry a new one if its something else though.
Junebug wrote:
I am 6'1" and about 220lbs so Basicly I look like a monkey humping a football on this thing but I love to ride it and I'm to old to give a shit about how I look on the thing.
 Post subject: Re: Ruck On Fire
PostPosted: Sun Sep 13, 2015 7:33 pm
Looking everything over, found a wire disconnected from the coil, yellow color.
Still dont think a loose wire or disconnected wire could created a back feed like that, help!
 Post subject: Re: Ruck On Fire, Help!
PostPosted: Mon Sep 14, 2015 7:16 am
Bump, help! Was dying to ride, any idea how to keep this from happening again?
PostPosted: Mon Sep 14, 2015 8:33 am
Gy6 swap... You won't need a ecu anymore.
After reading your post, no idea what could be causing youre ecu to be smoking.. Obviously it's shorting somewhere.
Ruck-U, Minnesota Chapter
HRGC Racing
Duckwing and keygaurd guy
PostPosted: Mon Sep 14, 2015 12:07 pm
Ill be pouring over the wire harness, see if i can find anything.
Im wanting to keep it 49cc right now, not ready to do an engine swap. Maybe someday if i GET bored
