 Post subject: Turn signal issue
PostPosted: Sun Jul 09, 2017 4:47 pm
Left my Ruckus for friends to use... Mistake!... It was is perfect condition and they obviously laid it down on the left side. Oh well, it's not the end of the world. However, the L front turn signal just lights up and does not blink. The back Left signal does not light up at all. The Right front and back work fine. Can some one please let me know what the problem is and what is the fix? Thank you!
 Post subject: Re: Turn signal issue
PostPosted: Sun Jul 09, 2017 5:45 pm
The bulb that isn't working is probably the issue. Check wires and buy a new bulb. The other one won't flash if the bulb is toast.
TT-350z wrote:
Build Thread
PostPosted: Sun Jul 09, 2017 5:57 pm
These worked for me fine: http://www.ebay.com/itm/4x-Clear-Small- ... 8h&vxp=mtr
