Post new topic Reply to topic  [ 17 posts ]  Go to page Previous  1, 2
 Post subject: Re: Ruckus won't start after CDI install
PostPosted: Wed Jan 18, 2017 4:47 pm
Until you verify the voltage drop on the battery quit pulling your hair out. Just hook your meter to the battery and flick the key and push the start button. In your video it kick started pretty easily. It did also run for a good bit. Meaning your wiring is probably fine. I still suspect the battery is no good. Just kick start that bitch :banger:
DC volts
LiteW8 wrote:
PostPosted: Thu Jan 19, 2017 6:32 am
I do agree that it's probably the battery, but why would it only kick start with the CDI not hooked up? With it hooked up, it won't kick start.
The Shadow Cycle
