Post new topic Reply to topic  [ 9 posts ]
 Post subject: reinforcing the brake light connection on an NCY lever
PostPosted: Tue Nov 15, 2016 9:37 am
Hi,
I'm wondering if anyone has any tips on how to reinforce the brake light switch spade connectors that plug into the NCY brake lever.
Those connections have a tendency to come loose when riding. I thought about taping them, but that would just wrap around the connection and not hold it in place.
I guess I could solder it on but is there some other kind of goo I could put on there to make that connection permanent?
Thanks!
-=l
 Post subject: Re: reinforcing the brake light connection on an NCY lever
PostPosted: Tue Nov 15, 2016 10:37 am
Have you tried crimping the connectors a little more? You may also try a zip tie to your throttle cable.
PostPosted: Tue Nov 15, 2016 11:56 am
heat shrink tubing, maybe?
Red rOOckus
gy6 super stretch
gy6 off-roader project
Yamaha C3
PostPosted: Tue Nov 15, 2016 11:59 am
I'm thinking I'll try both of those suggestions... I'll crimp it a little tighter and shrink tube it. That connection looks way to fragile as it is. When I installed it I thought I must be missing a part or something that goes over that connection but nope.
thanks
PostPosted: Tue Nov 15, 2016 12:59 pm
Hahaha... I did all three with mine.
PostPosted: Tue Nov 15, 2016 1:49 pm
I'm surprised its not shorting out! In the photo it doesn't look like there's much separating the two terminals, and no insulation.
Red rOOckus
gy6 super stretch
Yamaha C3
PostPosted: Tue Nov 15, 2016 2:31 pm
it's only been on the road for not even 30 mins post swap when the plugs fell out... I'm more worried about the connection breaking off from the lever and having to go source another lever just for the switch.
PostPosted: Tue Nov 15, 2016 2:45 pm
yeah... it's a pretty non-insulated connection. I would have thought there would be a cover or something.
PostPosted: Wed Nov 16, 2016 2:22 pm
My suggestion would be to ditch the connectors and solder the wires to the prongs and heat shrink over them.
TT-350z wrote:
Build Thread
