Post new topic Reply to topic  [ 26 posts ]  Go to page 1, 2  Next
 Post subject: Gy6 Won't start very close please read !
PostPosted: Thu Mar 08, 2012 4:47 pm
valves are set at 0.004 at the intake and 0.005 to the exhaust.
When i crank the bike with the sparkplug out and i press my thumb on the sparkplug hole i get pressure.
Spark plug is nice and blue when I ground it to the engine.
Spark plug is wet and at times when i crank the motor, smokes comes out of the exhaust.
When I had it started after taking it to a mechanic, It was running Way too rich and kept trying to die on me. It was popping like crazy and when i pulled out the plug it was black.
Its super easy to start when the motor has been running.
If the motor is cold it is almost impossible to start unless i press the starter for like 15-20 seconds.
I tried adjusting the float and its still not starting. There is fuel in the bowl so it looks like its getting fuel but maybe its getting too much somehow ?
http://totalruckus.com/phpBB3/viewtopic.php?f=92&t=59502&p=991701&hilit=dirtybitch#p991701
 Post subject: Re: Gy6 Won't start very close please read !
PostPosted: Mon Mar 12, 2012 12:07 pm
anybody ?? i really need some advice
PostPosted: Mon Mar 12, 2012 12:21 pm
Do you have electric start?
You could spray some starting fluid in the carb of it starts then it's a fuel issue
BIG EASY WEEKENDER 6 RALLY 2013
N.O.L.A. Ruckus Society
Zelchco's build thread
PostPosted: Mon Mar 12, 2012 12:36 pm
I did this exact same thing and mine started right up problem was I just couldn't get the pump to fill the bowl before the batterie would die
Urchin gone DarkUrchin
PostPosted: Mon Mar 12, 2012 2:57 pm
can i do this but with drops of gas ? i just ran out of carb cleaner :headbashing:
PostPosted: Mon Mar 12, 2012 4:55 pm
Yes that should work too.
PostPosted: Mon Mar 12, 2012 5:55 pm
Don't mean to piggy back, but I'm having a similar issue and looks like we've tried the same stuff. New gy6 with 50 miles on it. Ran awesome for a few days in a row and then the next day, crank, crank, crank, won't start. Checked every single wire, plug, hose, cleaned the carb (which was brand new and spotless), have spark, have fuel, and totally lost.
So, I'm waiting for you to solve both of our problems :)
2012 FZ6R
GY6 Ruckus SOLD
GS500 SOLD
Build thread viewtopic.php?f=37&t=60548
PostPosted: Mon Mar 12, 2012 5:58 pm
Try starting fluid to make sure it not loss of fuel
PostPosted: Mon Mar 12, 2012 6:04 pm
Do both of you guys have the fuel check valve on your fuel line?
Not saying that's the problem but that little peace helps out with starting for sure
Air, gas, spark & copression is what it needs to start.
Bypass the jets in the carb by using starting spray.
PostPosted: Mon Mar 12, 2012 6:08 pm
fyi the kickstart gear in the gy6 sometimes isnt aligned right so if u take it apart( its a bitch though) and put it back together it will kick easier
2t build
4t build
drowsports
standardfunctions
RUCKAHOLIC!
PostPosted: Wed Mar 14, 2012 6:05 pm
I've been trying starter fluid. Are you suggesting taking off the carb and then shooting in starter fluid?
2012 FZ6R
GY6 Ruckus SOLD
GS500 SOLD
PostPosted: Wed Mar 14, 2012 6:09 pm
no, you need the carb on there. Do you guys have vacuum pumps? If you do you can prime the carb by sucking on the vacuum line and fuel will flow into the carb. I'd make sure the carb is full. Do either of you guys have the ability to take video of the starting. It might help.
Check out my member ride
viewtopic.php?f=95&t=46393 , 90 percent done, 90 percent left to go!
PostPosted: Mon Mar 26, 2012 8:01 pm
So when i try and start the bike is takes forever to get it started and when it is started it runs really rich for some reason but its got a stock pilot jet and have a 105 main jet.
Now the spark is nice and blue, there is fuel in the bowl of the carb.
The only things that i could think of is carb angle, autochoke or jetting.
I JUST WANT TO START RIDING :(
PostPosted: Mon Mar 26, 2012 8:04 pm
What makes you say its rich?
PostPosted: Mon Mar 26, 2012 8:34 pm
when i rode it it was popping like crazy and when i would pull out the plug it would always come out black and sooty and eventually foul up and not let me start it unless i put a new plug in
