 Post subject: GY6 wont start.
PostPosted: Sat Oct 29, 2011 7:07 pm
recently did a swap on an 09' and everything worked out... wiring is good, got lights and electric start working but it doesnt fully start up. it was a brand new GY6 and harness... its got gas, oil... and still, when i try and fire it up... it just goes on. i can see smoke exit the exhaust but it kills my battery trying to start it from the electric switch. even when i kick start it, its a no go... anyone got any suggestions?
 Post subject: Re: GY6 wont start.
PostPosted: Sat Oct 29, 2011 7:47 pm
Auto choke or manual?
Fresh gas?
BIG EASY WEEKENDER 6 RALLY 2013
N.O.L.A. Ruckus Society
Zelchco's build thread
PostPosted: Sat Oct 29, 2011 8:30 pm
Spark plug(s) ok?
KillerScooter
DrowSports
Standard Functions
Sticky Belts
PostPosted: Sun Oct 30, 2011 12:07 pm
its auto.. gas is pretty new and spark plug is good... :meh:
PostPosted: Sun Oct 30, 2011 12:24 pm
Have you ever ran that motor befor?
You could try starting spray in the carb.
it could be an auto choke problem. Try to take the filter off the carb and cover it with your hand. To act like a choke
PostPosted: Sun Oct 30, 2011 12:28 pm
AHHHH the joys of the darkside! Good luck.
BUILD THREAD
AZRUCKSTARS
PostPosted: Sun Oct 30, 2011 12:36 pm
no, ive never ran the motor before its brand new fresh out of the package wrap. thanks guys! ill give it a shot
PostPosted: Sun Oct 30, 2011 12:40 pm
Have you pulled the plug and checked to see if it has spark?
The motor needs these 3 things to run.
Spark
Fuel
Air
Make sure all of these are there and it should fire.
PostPosted: Sun Oct 30, 2011 4:00 pm
Is the carb clean?
KillerScooter
DrowSports
Standard Functions
Sticky Belts
PostPosted: Fri Nov 04, 2011 4:34 pm
im having the same problem i hear a loud clank when try to start the bike
http://totalruckus.com/phpBB3/viewtopic.php?f=92&t=59502&p=991701&hilit=dirtybitch#p991701
PostPosted: Fri Nov 04, 2011 6:16 pm
I hear a loud clank from the starter on mine every time I try to start but dont hold the start long enough. I consider it normal but don't have much to comapare to. There is only one other GYruck around here so far.
When I start my bike I turn on the choke, push the start button, and opening the throttle just a bit.
PostPosted: Fri Nov 04, 2011 6:21 pm
I don't hear any clanks on mines
I like cookies
My Ride
PostPosted: Fri Nov 04, 2011 6:38 pm
Not even on failed starts?
PostPosted: Fri Nov 04, 2011 6:50 pm
Check if you have all the above mentioned things to get the motor running, spark, fuel, etc...
Can you hear it fire at all? Like will it try to start but you can't get into idle?
Let me know if its a problem with you going into idle, or if it doesn't even start at all.
If you can hear it fire but not go into idle then...
Go to your carb, screw in the idle screw a bit
Then try jetting
http://totalruckus.com/phpBB3/viewtopic.php?f=95&t=61928
PostPosted: Fri Nov 04, 2011 6:52 pm
Nope. It has a smooth turn/cranking sound and if my motor don't start, then it gets weaker and weaker until my battery drains. But no clanking sounds.
I like cookies
My Ride
