 Post subject: Bar-end mirrors for the Vino: easy to cut off grip ends?
PostPosted: Sun Oct 19, 2014 6:46 pm
Hi folks,
On my 2014 Metros I've replaced the stock stalk mirrors with bar-ends, which I far prefer.
I'd like to do the same on a 2006 Vino Classic; but unlike the Metro, the handlebar grips/throttle on the Vino cover the ends. Not sure if I really want to risk slicing off the ends of those rubber/plastic/whatever-they-are grips just to get access to the inside of the bar....
Has anyone else tried it?
SCOOTS
2014 Metro (blue) • 2014 Metro (orange) • 2013 Metro (black/red) • 2009 Metro (graphite) • 2008 Metro (gothic) • 2007 Metro (purple kanji) • 2006 Metro (salsa) • 2011 PCX 125 (red) • 2013 Yamaha Vino (vanilla)
 Post subject: Re: Bar-end mirrors for the Vino: easy to cut off grip ends?
PostPosted: Tue Oct 21, 2014 10:03 am
Idk about the vino specificaly but it should be the same as most any other grips. I did this on my ruckus. I just poked through the end with a razor knife and then worked my way out. On the throttle side check if your throttle tube is metal or plastic first. If plastic id use the same technique but remove the throttle tube from the bars first. If its metal you will need a hack saw or a drill.
Sent from my high tech wii-box thingy
2008 ruckus GET
http://totalruckus.com/phpBB3/viewtopic.php?f=95&t=87551&start=0
04 VW gti 1.8t
02 Toyota Tundra access cab 4x4 V8
PostPosted: Tue Oct 21, 2014 3:27 pm
make sure before doing any holes
that your throttle side bar doesnt have a plug welded in
my zuma did and what a nightmare that was clearing out
PostPosted: Tue Oct 21, 2014 7:15 pm
Great; thanks for the tip.
PostPosted: Tue Oct 21, 2014 7:17 pm
I'm such a newb to scoots.... :oops: How do I even remove the throttle grip from the bars? Is it pretty standard across different makes/models? -- just pull on 'em or something?
PostPosted: Tue Oct 21, 2014 8:49 pm
Yea pretty standard. To remove the throttle tube you will need to remove the control on the throttle side. There should be two screws on the bottom remove them the control will split in two. The throttle tube has a collar inside the control also the throttle cable it attached to the tube. You will need to pull some slack of the throttle cable to remove it from the throttle tube.
2008 ruckus GET
04 VW gti 1.8t
PostPosted: Sat Oct 25, 2014 5:32 pm
Awesome. Thanks panZer! That cleared it up for me.
PostPosted: Sat Oct 25, 2014 6:07 pm
Your welcome.. And welcome to total ruckus
2008 ruckus GET
04 VW gti 1.8t
