Post new topic Reply to topic  [ 88 posts ]  Go to page 1, 2, 3, 4, 5, 6  Next
 Post subject: Zuma 125 with turbo majesty 400 motor
PostPosted: Mon Oct 28, 2013 11:02 am
Parts are on there way to turbo mine on E85 corn gas. Put me a forged wiseco in so its ready for piping and tuning. It runs great now but I want ridiculous.
Any experience with power commander tuning on where to get a bigger injector is welcome.
 Post subject: Re: Zuma 125 with turbo majesty 400 motor
PostPosted: Mon Oct 28, 2013 11:28 am
in to watch :)
HRCA
GET POWA!!!
Proud Member of Team Floorboard!
kookookeedoo wrote:
Man, I miss the good old days when the noobs popped up and just wanted to know how to go 50... :headbashing:
PostPosted: Mon Oct 28, 2013 12:27 pm
:highfive: must see more!
2007 Honda Ruckus
viewtopic.php?f=92&t=91999&p=1553742#p1553742
2011 Yamaha C3
viewtopic.php?t=75689
2006 Yamaha Morphous
viewtopic.php?f=177&t=90661
PostPosted: Wed Oct 30, 2013 7:19 pm
I hate waiting on parts....ugh. Ship it already. Air fuel meter, turbo and blow off valve still not here.
PostPosted: Thu Oct 31, 2013 12:02 am
SICK :banger:
MiniMotorMonster 4T
MiniMotorMonster 2T
A Day in the Desert Ride
PostPosted: Thu Oct 31, 2013 5:02 am
you're one sick puppy.....and I like it! :banger: :banger: :banger:
ka0bit0™ z125'd Ruckus : Composimo x Makoa Scooters
Ver. 2 ^^^
Ver. 1.0 ↓
Follow the build on IG @ka0bit0 Image
PostPosted: Thu Oct 31, 2013 9:53 am
:popcorn: :popcorn: :popcorn: :popcorn: :popcorn:
My Scoot viewtopic.php?f=94&t=78819
PostPosted: Thu Oct 31, 2013 10:18 am
www.DROWsports.com
My 232cc GY6 Ruckus
PostPosted: Thu Oct 31, 2013 2:51 pm
subscribed for boost :canuck:
viewtopic.php?f=95&t=66569
PostPosted: Fri Nov 01, 2013 11:23 pm
The turbo, waste gate, fabrication, cooler, tuner and making boost is not a problem. Two big issues I have is the map sensor is vaccum and the throttle body is cv type operated off vacuum. A turbo engine does not have vaccum with the throttle open. I'm trying to research the map sensor to see exactly how it works and may try to run the throttle body without the slide. Pretty sure my tuner will overcome the 4-6psi fuel pressure loss ill have under boost. Otherwise I may delete the factory fuel regulator for an external 1 to 1 regulator for boost. Any ideas welcome.
PostPosted: Mon Nov 04, 2013 9:08 pm
I was just going to leave my compression alone and do low boost. Not the way to go. I'm going down to like 9.5-1 and putting boost to this thing. Taking the dome off my forged piston and running 3 base gaskets.
I want to run 10psi or so.
I'm building all the hot side piping, mounting the turbo, get this turbo stand alone oil setup on(diesel fuel pump runs 7psi to a 1/2 quart tank and crf50 oil cooler), then ill get the 1-1 boost monitoring fuel regulator and external pump on, cold piping on and my cute little 12X6X2 thick intercooler(that Blake said was huge) on there. Add my blow off valve. Think it will calm the pulsing though having volume. Ill just not hook it up to the throttle body yet. Run it to test oiling, the exhaust, my pumps, air fuel meter and tuner.
Think I can hold my hand over the intercooler outlet and see how much boost its going to try to make. Ill have to mod my waste gate rod to make it adjustable so it does build too much.
This thing is going to have more gauges than an airplane. Turbo oil pressure, boost, air/fuel meter, exhaust temp, fuel pressure and the regular gauges.
Think ill make the slide machanical too with a cable splitter.
I'm fired up! Waiting on $. Need a sponsor lol
PostPosted: Tue Nov 05, 2013 9:04 pm
PostPosted: Sat Nov 09, 2013 11:07 pm
Hot side started
PostPosted: Sun Nov 10, 2013 1:13 pm
Looks awesome so far!
Huge Fkn air filter lol :banger:
HRCA
GET POWA!!!
PostPosted: Sun Nov 10, 2013 1:35 pm
Is that a VZ21 or maybe the RHB31? I'm curious about the actual differences. I'm also curious to see what you come up with for your oil return. That's what has held me up with my turbo Ruck project, albeit a much smaller engine at 189cc. Careful, I blew out an oil cooler with my scavenge pump this summer, too much pressure, not free enough flow to the engine. I got it running and halfway tuned otherwise.
http://www.youtube.com/watch?v=wPrQRPQRnlw
This get's me excited to start messing with it again! :D
ElCapitan
Check out my turbo GY6 build!!!
