 Post subject: Could my Posh CDI have gone bad?
PostPosted: Wed Aug 17, 2016 7:53 am
Ive had the super battle CDI installed with no issues, but i never had a Tach. I just bought a Trailtech Vapor with dashboard and after the install, my ruckus had a rough idle and would bog heavily on throttle, topping out around 7mph. I adjusted the mixture screw and cleaned up the idle, but it still bogged on throttle.
Then i uninstalled my Posh and the ruck ran great, right up until 40mph. When i got home i reinstalled the Posh and ran into the same issue as before.
Question is, how do i know if my Posh has gone bad or not? Should i try an ECU reset after reinstalling the Posh?
 Post subject: Re: Could my Posh CDI have gone bad?
PostPosted: Wed Aug 17, 2016 10:35 am
If you reinstall the posh and disconnect the Vapor does it run proper?
the Ruckix
the Ruckus
60/49 club member
PostPosted: Thu Aug 18, 2016 7:16 am
Nope. But I am going to toy around with it today and see if I can come up with a solution.
PostPosted: Thu Aug 18, 2016 9:13 am
so after posting that i went out and started checking ish out. turns out i had the green wire slip out of the relay. all fixed, except my mnnthbx led flasher doesnt work. LEDs light up, another issue i was having, but they dont flash anymore.
