Post new topic Reply to topic  [ 72 posts ]  Go to page 1, 2, 3, 4, 5  Next
 Post subject: Hubs , GY6 , fATTY setup
PostPosted: Fri Dec 10, 2010 10:00 am
Hubs alone shipped.....$200...Available
ALL SALES FINAL. NO RETURNS
PAYPAL dorbyworks@hotmail.com
ADD short axle $30
Can also include rim/ rim tire stretch combo...pm for availability of wheels/tires
WHEEL TIRE /HUB package available
10x7
12x7
V2 HUB dual pattern
1 set of hardware included.. for both sets of hardware add $10 dollars
Gy6 150 cc drum hubs
compatible with
10x7
10x8
12x7
12x8
pattern dual pattern!! you can run 2 different types of wheels
4x110
4x4
shop for 3+4 or 4+3 with a 1" spacer
MOUNTS you can use!
"MOJO"
"Composimo"
Thank you all for having a great community.
Pictured below is V1 ..new hubs coming out will be dual pattern for wheel selection .
Gy6 ENGINE fatty hubs for 10x8 .
10x8 setup
DORBYWORKS FACE BOOK .http://www.facebook.com/dorbyworks
DORBYWORKS FORSALE VENDORS SECTION
http://totalruckus.com/phpBB3/viewforum.php?f=149
Vouch thread
viewtopic.php?f=82&t=43402
 Post subject: Re: Holiday Specials!CArbon exhaust. FATTY HUBS
PostPosted: Fri Dec 17, 2010 3:21 pm
Sup Dorby, you know the offset on the rims and will it line up with the composimo mount... think comp said the mount would work on a 3+4 offset
Ruckus Fatty Gy6
KeoNgot's Goods
PostPosted: Fri Dec 17, 2010 3:24 pm
i think 3+4 is for a 10x7....
i have
3+5 = 10x8
Vouch thread
PostPosted: Fri Dec 17, 2010 3:36 pm
Ive seen some 12" with 3+4 on the net i think the first # means 3 inch to the left of the rim which the hub will mount on to and 4" deep dish on the right? Also what bolt pattern are the hubs? thanks bro just making sure before i make the same mistake as last time with bad offsetting.... just doesnt ride right....
Ruckus Fatty Gy6
KeoNgot's Goods
PostPosted: Fri Dec 17, 2010 3:37 pm
Think yours looks more like a 5+2 but hey I might be wrong...
Ruckus Fatty Gy6
KeoNgot's Goods
PostPosted: Fri Dec 17, 2010 6:50 pm
That rim only came in a 2+5 offset (thats for the front atv wheel) and a 3+4 for (for the rear
Atv wheel)
Trust me I know I researched that 5 spoke wheel for a long time and i got to believe one of the last ones in the entire usa with the 3+4 offset unless u find a store that has one in there wearhouse
Also that wheel has been discontinued for over 7 months.
My Ruckus viewtopic.php?f=96&t=51292
My Met GET 57+mph fast and low build viewtopic.php?f=96&t=63705
My how to polish viewtopic.php?f=34&t=65740
PostPosted: Sat Dec 18, 2010 10:59 am
Atv wheel)
yes the 5 spoek i have is 2+5 so the engine would need to be spaced out 1" further to the left to be dead center. Would work on a weld on mount like Mojo's with tabs welded accordingly
Vouch thread
PostPosted: Sat Dec 18, 2010 9:35 pm
Ahh thanks for the info fellas, looks like I'm gonna have to go another route :pissed:
Ruckus Fatty Gy6
KeoNgot's Goods
PostPosted: Wed Dec 22, 2010 10:22 am
Any pix of just the hub? You can't really see it when it's mounted... and what's the bolt pattern?
So, back to the topic.
Don't talking about ruckus with ferrari engine anymore.
MY BUILD THREAD
PostPosted: Fri Dec 24, 2010 3:25 pm
in for pics as well.
http://totalruckus.com/phpBB3/viewtopic.php?f=93&t=56217
she is gonna need a name soon....
PostPosted: Fri Dec 24, 2010 5:25 pm
Tempting exhaust. Would be potentially using it on a GY6
Likes Phở
TinyElvis
PostPosted: Tue Dec 28, 2010 8:51 am
Finding a 12x7 3:4 4x100mm is not a easy task at all. I have ordered 3 rims so far. They all ended up being 2+5.
2 of the 5 spoke rokstars both were listed as 3:4 and when I received them they were 2:5.
Also you can not add a spacer to a 2:5 offset. When you mount a 2:5 the wheel is over to the right a inch to far. By adding a spacer its only going to push you over more. A spacer would work if the offset was 4:3 then you could push it over a inch. A 4:3 is to far over on the left it will hit the cvt case. One other thing is that these golf kart sites don't keep their sites updated well. I have called alot of company's that had a 12x7 3:4 rim listed to find out that it wasn't in stock.
My Build
viewtopic.php?f=95&t=70063&p=1212609#p1212609
PostPosted: Thu Dec 30, 2010 10:16 am
How does the hub attach to the wheel? Does the customer drill their own holes and add studs?
My Scoot.
viewtopic.php?f=95&t=37866
PostPosted: Thu Dec 30, 2010 1:54 pm
hubs are tapped .they can be used for 4x110
Vouch thread
PostPosted: Thu Dec 30, 2010 2:45 pm
Ah, well thats cool. :banger:
My Scoot.
