Post new topic Reply to topic  [ 43 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Rugger's 1982 C70 Project
PostPosted: Tue Apr 28, 2015 6:37 pm
One I worked on which is a 69 cm90 I think
lifan 125 semi auto
the rear sprocket used 4 bolts and nuts to tighten to the hub
those kept coming loose, and jamming up the wheel from spinning
pretty hard fix on the side of the road, and very dangerous if the bolts didnt bend and slowly jam it to a stop
im pretty sure yours uses the same bolts to mount it
I ended up tack welding the bolts and nuts as even replacing them and using loc tite they still vibrated loose
alot of parts on that bike started to vibrate loose when riding it
and it barely seen any road time
I suggest every bolt, and nut be loctited, and if you can safety wire and cotter pin
at those high speeds things start to work their way loose
PostPosted: Tue Apr 28, 2015 8:03 pm
I hear you Mike. I've owned thumpers before XR250, last one was a KLR650 - every damn bolt would come loose on them. I've heard about the rear on sprocket on the C70 needing to be tack welded with bigger engine running.
I've found routes from our place into town without the need for high speed - not the most direct, but I can make it work. Most likely I will wind up flipping this thing for something with a bit more power unless my youngsters really take a liking to it. We live in a semi-rural subdivision outside of Austin - 3-15 acres lots, creeks, trails, etc...so they will probably have ball for a while until they start asking for dirt bikes.
1982 Honda C70 Passport Project Blog
Youtubes
PostPosted: Wed Apr 29, 2015 5:44 pm
Installed the 3.00 Gazelle on the rear today. My gut tells me that additional rolling mass is definitely affecting the pick up and the uphill speed.
Just one very short ride on it, but that's my gut. The 3.00 is a tight fit, you definitely have to center the wheel or you'll get some rubbing - naturally you want it centered anyway.
Mike, unless I'm mistaken, my C70 has some locking tabs that keep the bolts from moving. I should have taken a picture when I had the wheel off. I'll see if I can get a pic.
Compare
2.5 Before
After 3.00
Definitely a better, more aggro look.
Youtubes
PostPosted: Wed Apr 29, 2015 6:59 pm
yeah that cm90 I worked on had the fat tires too
maybe the newer models have that locking tab on the rear wheel nuts
the one I worked on was 1969
PostPosted: Wed Apr 29, 2015 8:08 pm
I went with the 2.75 up front. You either have to drop that little plastic fork crown cover or trim it unless you like the tire rubbing it.
Front compare
Looks much cooler with the big rubber
With her clothes back on...looks pretty good...
Youtubes
PostPosted: Wed Apr 29, 2015 8:13 pm
look up street cub bitches on IG
they put some very wide wheels up front on most of the cubs
I think the widen the forks somehow or its off another model
PostPosted: Wed Apr 29, 2015 8:19 pm
They definitely widen them.
Youtubes
PostPosted: Sat May 02, 2015 7:05 pm
those are awesome :banger:
Helmets are for wearing.
[DRTY RUCK Build thread]
[METROPOLIS Build thread]
[C3 Slow Build thread]
Sincerely, dodgrr
PostPosted: Tue May 05, 2015 10:57 am
Youtubes
PostPosted: Fri May 08, 2015 6:17 pm
New tank arrived, it is in good shape. Installed.
Bike looks a lot less death trappy with the actual tank in it. I pulled off the front turn signals off. I plan to put a couple of mini round flush mount lights there.
Bike is starting to look a bit cooler. I need to do something about the seat, the bog stock seat looks funny on the chopped fender.
Youtubes
PostPosted: Fri May 08, 2015 8:03 pm
there are single length seats available
my friend had one but to me it looked too short
I suppose you could chop the pan down and make the seat the exact length you wanted too
did that tank have a fuel sender in it?
PostPosted: Sun May 10, 2015 12:07 pm
I could have sworn I replied last night...
Agreed, I think they look odd - the short ones.
Thinking of cuttting the pan/seat, shave the height down and reupolster it.
It does, but not finding a gauge I like.
I acquired a couple more Hondas y'day...not exactly minis though, two 87 XL250Rs, 1 a registered great running bike, the other a "parts" bike, but it looks pretty complete and even has a new jug, head and cover to install.
Youtubes
PostPosted: Wed Jul 01, 2015 7:18 pm
Yeah?! I was wondering that too. It looks like it's got a fuel gauge installed on it. I didn't know they made those!
1976 Honda GL1000
1973 Yamaha TX500
1950 Yamaha YDS-1
1964 Suzuki T10
1965 Suzuki T250
1972 Honda CL450
1978 Yamaha XS650
1982 Honda Passport C70
