Post new topic Reply to topic  [ 59 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: '73 Trail 90
PostPosted: Wed Jul 31, 2013 1:39 am
digging it!
My '63 Honda Cub Build Thread
My GROM Build Thread
First ECC (Extend Cub Club) Member in the United States
PostPosted: Wed Jul 31, 2013 9:26 pm
This whole time, I haven't been able to get spark. Checked my coil, good. Spliced on a new wire. Replaced my points, condenser, and a number of connectors. What I didn't replace got a good dose of electronic cleaner and some dielectric grease. I had spark at the points, and occasional spark at the plug... WTF?!
This morning I realized that the wire connecting to the points was on backwords, and grounding against the cover when I put it on. Flipped it around and it started on the first kick. :headbashing: but :banger: at the same time.
I'm riding bitches!
Gonna get my winker relay this weekend, buy some mirrors, and I'm ready to go get legal. FAAAAAAAK YEAAAAAAHHHHHH
-I eat golf carts off the line-
'95 GY6 Yamaha Razz
'73 CT90
PostPosted: Wed Jul 31, 2013 10:24 pm
This thing is dope!! :highfive: :banger:
Blue Typhoon STOLEN
Manilla Gorilla SOLD
Black Betty x Dirty Gerdy
PostPosted: Fri Aug 02, 2013 5:18 pm
Let's see some daytime photos! The bike looks great!
(4) CT70's - http://totalruckus.com/phpBB3/viewtopic.php?f=145&t=69961
PostPosted: Sun Aug 04, 2013 4:21 pm
Soon enough! I got it running, and it runs pretty nice. I think the timing advance spring is shot though, as after going off throttle it stays revved up. The slide in the carb is returning, and it's only after you physically slow the bike down/apply brakes to the rear wheel that they drop back to idle.
Main issue is, I don't think it's charging. The (brand new) battery went damn near dead after 2 or three rides of less than a mile.
I'll try to get some better pics soon... Kinda want to get the front fender mounted and the clearcoat on the painted bits before I take any more pics.
'95 GY6 Yamaha Razz
'73 CT90
PostPosted: Thu Aug 08, 2013 6:10 pm
update Im thinking about picking up one of these.
http://totalruckus.com/phpBB3/viewtopic.php?f=95&t=61777
PostPosted: Thu Aug 15, 2013 12:54 pm
So I fiiiinnnnaaalllly got to work on the CT90 a bit this morning. I got the front fender pretty well sorted, and mocked up a much better exhaust. I had been running a straight pipe with a diffuser at the end, but it was just too loud to me. I chopped the stock muffler up previously and found it's two chambers, so I just stuck one chamber on. It's not welded yet. Also haven't welded up the hardtail sleeves yet, because I want MOAR LOW
Got some new pics, too. As of 15 minutes ago:
'95 GY6 Yamaha Razz
'73 CT90
PostPosted: Mon Sep 09, 2013 4:35 pm
I just welded up the exhaust this morning. Also welded up the hard tail, and did most of the wiring for the winkers. Was having charging issues, and my new battery is dead.
I'm done with this 6V bullshit, I'm converting to 12V.
I talked to a guy here that had done a 12V conversion on his K4 and he said he just replaced the battery, rectifier, and bulbs.
Does this sound legit?
'95 GY6 Yamaha Razz
'73 CT90
PostPosted: Mon Sep 09, 2013 5:03 pm
diggin it trav!!!
Cookie
viewtopic.php?f=92&t=45567
PostPosted: Wed Sep 11, 2013 11:16 am
Thanks for the comments guys!
I think I solved the charging issue... or at least it seems like it. Narrowed down a bad ground on the rectifier. Clearcoated a bunch of stuff yesterday, and mounted my mirrors too. I cleaned up the spark advancer shaft and reset my points. Then I ran out of energy because of a damn cold. I just started it today and she runs like butter.
Ran it down the road and it still sputters a bit at balls-out in 4th gear, and takes a second to drop revs after blipping the throttle. This was, however massively improved by returning the carb to stock position (facing back of bike) and routing the throttle cable directly from handlebar->between legs->carb. Looks awful, works wonders.
I also fixed the throttle control/twist and turn signal.
Three weeks ago, I started the bike and put it in first to pull it into the carport (open on both ends). When I hit the throttle, it stuck wide open and shot me straight towards my landlord's brand new car 15 feet away. Somehow I got it pointed away from the car and missed it by about 6", only to hit a rock wall behind the carport and lay the bike down. Broke a turn signal, put some small scrapes in the paint (on the bike, not the car!), and got some nice raspberries down my left side. All in all I came out lucky.
I'mma leave the scratches in the paint, just so it doesn't try to claim another round of 'first blood'.
'95 GY6 Yamaha Razz
'73 CT90
PostPosted: Thu Oct 17, 2013 6:26 pm
Figured out my carb float was taking on fuel. I ordered another PZ19 off ebay, and it should be here monday. In the meantime, I had 17 days off thanks too a bunch of childish assholes in congress... I did lots of detail work; tidied up wiring, signal mounts, touched up some spots in the paint and went through using the Hawaii safety check as a guide. Got my MC license, too. I hope to be riding soon.
'95 GY6 Yamaha Razz
'73 CT90
PostPosted: Thu Oct 17, 2013 7:26 pm
So cool, the vintage shit is. If I knew how to make one run good id wanna get one, maybe some day! Nice work Trav
PostPosted: Thu Oct 17, 2013 7:54 pm
my float did the same exact thing
but at 11pm on the darkest most desolate road and super cold
luckily I was able to use my spare gas can to get to a gas station
only to have the carb overflow the fuel out the whole time but I was able to make it to my dads barely
but mine was the stock carb so im using an aftermarket one now
PostPosted: Fri Oct 18, 2013 11:40 am
Hey Mike, just out of curiosity, when your float sprung a leak, did it suddenly feel like it had the choke on?
'95 GY6 Yamaha Razz
'73 CT90
PostPosted: Sun Nov 24, 2013 11:27 pm
nope
I ran out of gas
then when filling from the spare tank I noticed gas all over the ground
make sure you check for air leaks
on that plastic intake spacer I always put rtv on all those fittings I dont care if they use o rings or paper gasket
ive had brand new ones leak
just get some brake cleaner and with bike running spray all over those areas if idle drops or dies you have an air leak
there are so many things to check if its running weird
I always had a bad studder when accelerating and even had to replace the spark plugs every 100 miles until I replaces the valve seal
now im over 300 miles on the same plug
for mine I ended up slowly replacing every electrical part on the bike after that
and later found my little weird miss when accelerating was because the turn signal was on
if its off I have perfect running bike at acceleration
couldnt believe how long that took to figure out
and I couldnt set timing to specs I had to advance or retard it by feel on the road to get how I wanted it to run
mostly it effected acceleration and high revs in first gear
but its possible my cheap tach wasnt the best and I was never really at the correct idle when setting the timing anyways
