Post new topic Reply to topic  [ 47 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: 81 Honda Passport C70
PostPosted: Fri Jan 18, 2013 7:23 pm
^Bah- wait til you see what you got. I'd go for a domed 88 kit myself, or a jdm kit. Those big horizontals will work with a little... fitment.
Look up Tbolt if you want to spend cash or a new motor.
RUCKUS DAY- April 15th!!!
viewtopic.php?f=95&t=99
PostPosted: Fri Jan 18, 2013 7:24 pm
that engine has a clutch
sort of hard to add a clutch lever to a passort
you have that metal thing covering the bars, plus the bars arent the typical 7/8
but nothing is impossible
I see it has a shitty oil cooler too , would have to find a place to mount that too and with the leg shield in the way may be hard to get good flow to it
look for semi auto
N, 1, 2, 3, 4 pattern
the one you linked have common problems skipping out of gear with that shift pattern
not all of them but enough of them do that
oh yeah I think anything under 1981 will be 6 volt
so that engine is 12v, you will need probably $50 or more in parts to convert down to 6 volt, or just about the same to convert the bike to 12v by replacing all the bulbs in the bike
PostPosted: Fri Jan 18, 2013 7:52 pm
i'd rather convert to 12v, more options to play with in the electrical world. now for finding the auto shifting motor, is going to be a little difficult.. but thanks for the info i will keep my eyes open and send you some of the deals i find.
82 Honda Passport C70 Build
PostPosted: Fri Jan 18, 2013 7:57 pm
im thinking there is no semi auto 140cc
but there are tons of semi auto 125cc
PostPosted: Fri Jan 18, 2013 8:12 pm
Hype it up Mike! :twisted:
My Ruckus Build Thread NEW
Non-Ruckus Build
Buyers Feedback
PostPosted: Fri Jan 18, 2013 8:20 pm
passport is the shit
you get all the girls, turn all the heads, and look boss driving one
and the leg shield keeps your skirt from blowing up :banger:
PostPosted: Fri Jan 18, 2013 9:09 pm
PostPosted: Fri Jan 18, 2013 9:17 pm
damn I should get a kilt
think I could pull that look off
PostPosted: Sat Feb 02, 2013 10:26 pm
I have a family member that makes custom kilts. Pm me for deets.
Build threadminimadman's crazy projects
03'120cc xr/ape
02'RC51 fs
TRmember#2217
Scooterman=RINGSTAMP APPROVAL!!!
AZRuckstars
DriverSideImpact1008 wrote:
And the Lord said unto John, "Come forth and receive eternal life."But John came fifth and received a toaster.
PostPosted: Sun Feb 03, 2013 7:56 pm
bought new whitewall inserts
the other ones I tried were from a wider tire and were used
they popped off riding would slip out of the bead or flap enough and slip out
so hopefully I dont have that problem
so far they have held and not moved any
treatland tv was the cheapest price ive seen like $30 shipped for all 4 inserts
bad night pic
install is easy but you have to take the wheels off the bike
the rear takes the longest
and I used this trick to keep it from accidentally closing the center stand, which has happened in the past when fighting the rear tire off
just deflate and break the bead
then slip in these inserts and fill
then you may have to deflate and adjust and fill tire again
if you take your time they will sit in evenly
you can get a slight bubble if you dont inspect them after inflating they will slightly move when inflating
PostPosted: Thu Feb 07, 2013 7:15 am
PostPosted: Sun Feb 10, 2013 5:22 pm
PostPosted: Thu Mar 07, 2013 4:25 pm
I think there may have been a run of the 140 semi autos years ago but they are usually 125 max. Wonder if a stroker crank would work in a 125auto. People are talking about the kickstart lifans being phased out.
PostPosted: Thu Mar 07, 2013 4:32 pm
no way they can phase them out
so many dirtbikes that run lifan engines that only kickstart
I can see phasing out electric start
just adds more weight and they are so easy to kick over anyways
PostPosted: Fri Mar 08, 2013 8:49 am
No, just the semi-auto models. Crappy clutch versions only.
