 Post subject: Having powdercoat etched?
PostPosted: Thu Mar 17, 2016 9:07 pm
I'd like to have something etched , after its pc'd.... is this possible? Likelihood of a good outcome?
Schanks schudes! :banger: :wasted:
fuck.
The way it should be Kitchen mechanic
 Post subject: Re: Having powdercoat etched?
PostPosted: Sat Apr 16, 2016 10:23 am
Etched like with a laser, or engraved like physically removing material to show the metal underneath? You need a real powerful (think co2, 40+w) laser and some CerMark to sinter off the top layer of PC (anodized works as well) but it does work.
Etched like with an engraving bit or endmill is likely a lot easier, but feasibility comes down to what part you're working with and what your desired results are.
Maybe, just once, someone will call me 'Sir' without adding, 'You're making a scene.'
GET EVIL 66.6cc build
PostPosted: Sat Apr 16, 2016 1:21 pm
I'm thinking hand etched... I'll talk to a local engraver once the part is pc'd and see what they say.
fuck.
PostPosted: Sat Apr 16, 2016 2:48 pm
I wonder will it splinter or crack around the engraved part?
LiteW8 wrote:
PostPosted: Sat Apr 16, 2016 3:06 pm
I wonder too, the engraver I'm going to talk to has been in town for 30+ years, if they feel confident in doing it I'll let them try....... :meh:
fuck.
PostPosted: Sat Apr 16, 2016 3:40 pm
Depends on the part and how deep you're engraving. This was .15mm and I doubt it affected the part structurally.
PostPosted: Sat Apr 16, 2016 3:56 pm
I mean the powder coat chipping rather then clean lines
PostPosted: Sun Apr 17, 2016 12:48 pm
I was envisioning like acid etch.. like they do glass.. or like acrylic where you use a light media blast to etch the open sections of a decal
250 build viewtopic.php?f=92&t=91906&p=1553160#p1553160
PostPosted: Mon Aug 22, 2016 12:13 am
Have you talked to the man?
King Ghidorah
ultramagnus wrote:
PostPosted: Mon Aug 22, 2016 12:26 am
Nope, I Woodin,I have a friend who is close with them and had a lot of work done
fuck.
