Post new topic Reply to topic  [ 133 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9  Next
 Post subject: wire tuck tips and tricks
PostPosted: Tue Sep 17, 2013 11:47 am
Been there done that! It's part of the process. Routing your wires DOES affect cable length. So take that into account..
Version2.0 wrote:
ruckhero wrote:
Version, just FYI in my tuck, I did two smaller holes on the left side. One for brake and one for throttle. Was nervous to do one large hole for both but either should work. I also tried to drill in between any of the cross castings so the frame still had as much rigidness as possible.
Awesome! Thanks for the tip!
Did it affect the cable lengths? Like GETSLIM?
I still have to try to route my cables.... Seems I'm in a constant assemble-reassemble situation, lol! It will probably be taken apart and mocked up at least three more times before paint! :wasted:
 Post subject: Re: wire tuck tips and tricks
PostPosted: Sun Sep 22, 2013 12:50 am
Curious where everyone gets their longer throttle cables........
I "cleaned up" my wiring back in 09. Now that the ruck is getting an overhaul this winter, an all out tuck will be underway.....among other things.
And GETslim, love the milspec wiring. Props.
~Marine Snipers: America's Number One Long Distance Service Provider~
~In a crisis, an operator will not rise to the occasion, but rather sink to the level of their training~
PostPosted: Sun Sep 22, 2013 10:42 am
Motion pro makes em exactly how you want them and for pretty damn cheap. That's where I got my throttle cable and brake cable made
to my exact specs.
PostPosted: Tue Sep 24, 2013 11:44 am
Thanks. After posting I was sifting through my "bookmarks" and found a link to them from a while ago. I guess I already read about it once before, smashed the bookmark button, and kept on cruising. :ucrazy:
I'm still not sure on drilling holes in my frame. I'm 300lbs, so i'm attempting to be careful on how I modify. It may sound silly, but in the interest of safety (but still being able to mod) I am thinking about welding a small diameter tube to the underside of the rear frame and run wires in that.......drill holes in that. With a clean enough weld/fill job, it would just look like the frame is egg shaped. To joe public, they wouldn't even notice. Frame dexterity saved.
Thoughts? I understand it may add extra weight, but really........when I'm 300lbs already what is a 2 pound little pipe going to add that another cheeseburger won't?
PostPosted: Tue Sep 24, 2013 1:17 pm
Is your frame right handed or left handed???
5prock3t'5 09 RED Ruckus
PostPosted: Wed Sep 25, 2013 1:36 pm
lol......i now see the error in my ways.
PostPosted: Thu Sep 26, 2013 7:52 pm
GETSlim wrote:
Drilled the frame so running harness..rear brake and throttle cables was easier..actually gained length with the cables by going this route as well
Sank You!! :banger:
My build(s) thread
New Stuff Fo Sale
PostPosted: Sun Nov 17, 2013 2:40 pm
Great thread! Will certainly try to run the wires through the neck. Really don't want to get crazy with extending wires yet.
2003 Ruckus- Black and Chrome
viewtopic.php?f=92&t=86370
Girl Friends 2003 Ruck
viewtopic.php?f=92&t=89000
The Carburetor Boys
The Carburetor Boys
PostPosted: Fri Nov 22, 2013 9:08 am
Still running factory length cables although I'd love to extend the rear one some..seems to engage when the suspension flexed a lot..feels the rear brake drag some..
And that hole is the only hole drilled into the frame..where I've drilled. Is the thickest part of the frame so I'm not concerned about anything happening..
To me..if the rider is exceeding the factory 225lb limit..I highly suggest a front frame support like a chin bone for some peace of mind..
49cc
1(900)GET-SLIM
Robomod wrote:
tunahs tune and ruckas tuck
PostPosted: Fri Nov 22, 2013 9:43 am
If anyone is concerned about drilling too large of a hole in the front frame, drill a couple in between each of the "x brace" castings... like I did. If you look at the front of the front frame, or feel for them you can get holes in between each of the x's and keep the frame's rigidness...
PostPosted: Sun Dec 29, 2013 1:39 am
Damn slim that is the sexiest wire tuck I've ever seen. Didn't know this is what you did. Just read the whole thread because I finally have enough stuff to start a ground up build and I want to take my time and do it right. I hope to do a wire tuck, but I think I might be in a bit over my head.
BUILDS
DD beater http://www.totalruckus.com/phpBB3/viewtopic.php?f=96&t=85294
background build http://www.totalruckus.com/phpBB3/viewtopic.php?f=96&t=87090
Skipbarber wrote:
PS: Ever notice that the more you spend on a ruckus, the less of it there seems to be?
PostPosted: Sun Dec 29, 2013 11:11 pm
bump'd for review later.
PostPosted: Fri Jan 24, 2014 8:29 am
Subscribed.
Sold my first build and bought this one.
This one is getting rebuilt this winter with the help of some good friends.
I couldn't help myself and bought this one too.
PostPosted: Thu Feb 27, 2014 8:26 pm
Nice!!!!
The Build-http://totalruckus.com/phpBB3/viewtopic.php?f=94&t=87411
PostPosted: Mon Mar 31, 2014 10:54 am
This thread is dead…anybody got anymore pics of their setup? i got DROWsports Milspec harness coming in soon but i dunno if i got the balls to start hacking at the harness O_o
My Build Thread: viewtopic.php?f=96&t=88268
