Post new topic Reply to topic  [ 240 posts ]  Go to page Previous  1 ... 11, 12, 13, 14, 15, 16  Next
 Post subject: Re: the HID thread (high intensity discharge headlamps)
PostPosted: Mon Oct 03, 2011 7:08 pm
s-low wrote:
i've been running the arc 600k hi/low beam h4 kit for almost a month with no issues. plug and play kit, i just start the bike with the high beams on (normal halogen bulb), then when the bike is warm i turn the hid on. turned the idle up slightly and have no flicker, even holding brake lever and turn signals on. idle is about normal too. loving the one hid, one normal bulb setup
same thing, but 2 hids for me, just no high beams..dont need them tho
My Ruck-
viewtopic.php?f=92&t=59091
FOR SALE!!!
PostPosted: Tue Oct 25, 2011 11:00 pm
does anyone with after market headlight use the "stock hi-low switch" as on-off? if yes, can you guys post a picture, i need it for 1 hid ( 1 ballast ) that i'm using.
"El Colombiano" Build
PostPosted: Wed Oct 26, 2011 2:06 am
i am, but what kind of picture do you need?
MY OLD 40K MILE RUCK
MY JANKY NEW BUILD
PostPosted: Fri Oct 28, 2011 3:37 pm
TT-350z can you post a picture of how you ran your ground. I get what your saying about not using the factory one because it sucks but I cant picture how you got around the factory ground, did you just not use the factory headlight plug at all and ran wires? basically just looking for a picture of your entire wiring setup if possible. It would be greatly appreciated.
PostPosted: Fri Oct 28, 2011 3:42 pm
we probably dont wanna get into how mines done, thats a whole different ballgame lol i dont wanna confuse you all
you can just cut the ground wire off the plug on the hid, or the factory plug and ground it to the frame, its that easy
personally i would cut it on the hid side, so its a easy switch back to stock if ever needed
MY JANKY NEW BUILD
PostPosted: Fri Oct 28, 2011 3:46 pm
Yes I has one too 5000k is bright as hell but my old batt dying but I ll order new battery then I will reinstall on my ruckus heehee
Sent from my LG-VM670 using Tapatalk
my rides
viewtopic.php?f=95&t=54864
my 2007 Honda ruckus is sold ! this is history for now now for 2016 Jan 7 bought new honda mets 2014 blue I still grand Rapids michigan
PostPosted: Wed Nov 02, 2011 7:11 am
Haha gotcha. Have you had any problems with it killing your battery at all? After seeing a few people talking about it running ok but draining off the battery its kinda turned me away a little, guess i could always use these as backups in case the ones in my truck or car die :lol:
PostPosted: Wed Nov 02, 2011 10:00 am
i have had zero issues
but normally i only ride with 1 on
a long time ago i used both all the time with no issues to
but now i dont have a kickstarter so im a lil more easy on it, cant afford to be stranded
MY JANKY NEW BUILD
PostPosted: Wed Nov 02, 2011 10:05 am
Sounds good, Ill be giving it a try this weekend then. Ground wire on HID straight to frame and see how it works out. I appreciate the information man.
PostPosted: Tue Nov 08, 2011 8:37 pm
i have a quick question. i will be using a PIAA 3000 style light, which i can use 2 hid light, i will be using a HID relay harness from DDtuning, but how can i use the stock hi/low switch as on/off switch?
PostPosted: Wed Nov 09, 2011 1:03 am
are you using 2 ballast for hid lamp so you need to install a separate switch i have 2 hid 5000k but i was uninstalled due of my battery is no good wait til get a better battery i will re-install will be good to go please don't use damn lead acid battery !!! they gonna kills your ballast if you on under 6amp loads is gonna killed the ballast !!!! so need a dry cell type battery from odyssey orange battery (army grade) they wont kills the ballast because they are over the 6amps is much better and stables that i still planning to purchase a battery very soon that why i am very critically needed replace battery
my rides
PostPosted: Wed Nov 09, 2011 9:29 am
whatever you do, dont listen to that guy ^^^
MY JANKY NEW BUILD
PostPosted: Wed Nov 16, 2011 1:23 pm
run your light off high...dont wire your low beam...then when u switch to low it will get no power..
My Ape hanging Ruck
PostPosted: Wed Dec 14, 2011 12:21 pm
mix123 wrote:
I am going to try this harness and see if it works....can;t see why it wouldnt....
HEy
So i have and '09 ruck, and i went out and purchased this relay. and it works fine. will post pictures later. maybe video too. I used it with the xentec ultra slim 6000k single beam. as of right now i can use my hi low switch as an on/off
PostPosted: Mon Jan 16, 2012 2:41 pm
Swreelin wrote:
HEy
Pics? ...vids?....
I'm considering ordering this harness....but at the same time think I'm better off just buying a relay and calling it a day. :dubious:
ka0bit0™ z125'd Ruckus : Composimo x Makoa Scooters
Ver. 2 ^^^
Ver. 1.0 ↓
Follow the build on IG @ka0bit0 Image
