Post new topic Reply to topic  [ 77 posts ]  Go to page 1, 2, 3, 4, 5, 6  Next
 Post subject: 180cc GY6 w/carb, 8-pole stator, CDI, Coil, Regulator $825!!
PostPosted: Wed Oct 28, 2009 1:48 pm
We have been getting so may phone calls lately wanting complete engines for Ruckus Swaps. WELL 150cc is never enough so we have stocked up on some engines and are tearing them apart and boring the cases for the 63mm bore and blue printing the bottom end while we are at it!!!!
Package includes:
Stock crank
63mm cylinder with cast piston
8-pole stator and flywheel
8-pole Regulator/Rectifier
Stock Rubber intake manifold
24mm CVK carb
Stock Camshaft
Stock Valve Train
Stock CDI
Stock Coil
Stock Long Axle
Completely Stock transmission (variator, clutch, belt)
Rear Brake Pads
Starter Solinoid
This is a complete engine. Just add a mount and wire harness and this thing is ready to ride!!!
$825 plus shipping
180cc Options:
JE Forged Piston ($200)
Stroker Cranks (190cc upgrade $180)
Ported Heads ($150)
Upgraded valve train (to over 14,000rpms) (starting at $65)
Performance Camshafts ($65)
Taller Rear end Gears ($50)
Any Transmission upgrades you can think of
Larger Carbs (up to the big nasty 33mm flat slide pumper carb!!!)
Air Filters
Exhaust Systems (Stainless Steel systems Starting at $170)
Short Axles ($25)
Upgraded Starter Clutch ($50) HIGHLY recommended for high compression stroker motors.
11-pole Stator and regulator/rectifier ($60)
IF you have any questions please feel free to PM, Email or call us at the shop (515-309-1722)
Lead time on these engines are 1-3 weeks depending on options.
We also can sell the stock 150cc engine with the electronics and carb for $495 plus shipping.
150cc Options:
160cc Upgrade ($140)
Ported Heads ($150)
Any Transmission upgrades you can think of Dr. Pulley, NCY, Polini, ect...
Larger Carbs (30mm CVK works killer on ported cammed 150cc engine)
Air Filters
Short Axles ($25)
11-pole Stator and regulator/rectifier ($50)
For all performance or stock for that matter we ALWAYS recommend an oil cooler!!
Due to riding core engine cost we are not longer able to offer the 11-pole stator as standard it is now a $60 upgrade.
Please Call to order 515-256-9062
NEW WEBSITE UP http://WWW.SCOOTERS4LIFE.COM
KS Power/NCY Project Zero Build
NEW Scooters 4 life Project LEFTOVERS
SUPPORT THOSE WHO SUPPORT THE SCENE
 Post subject: Re: 180cc GY6 w/carb, 11-pole stator, CDI, Coil, Regulator $825
PostPosted: Wed Oct 28, 2009 3:23 pm
Bump for a great seller and a wicked motor.
Click Here for GY6 Fatty Mounts, Frames, and Custom Fab
2001 Honda Prelude - 700+ whp/500+wtq in full street trim
2001 Toyota Tacoma TRD SR5 - 5" of lift, stuffing 34's, full armor, locked
PostPosted: Fri Oct 30, 2009 7:38 am
Thanks man.. Also thanks for the wire harness!!
PostPosted: Sun Nov 01, 2009 11:40 pm
How much are your options?
PostPosted: Mon Nov 02, 2009 8:27 am
can you do just the engine with a crank and 63 mm cyl, im allready gy6 and got all the other stuff
-Mark-
PostPosted: Mon Nov 02, 2009 9:17 am
We can do that. PM with what you are wanting and I will give you quote.
PostPosted: Mon Nov 02, 2009 9:19 am
There really are too many to list. IF you want PM with the options you want and I will quote it out.
PostPosted: Mon Nov 02, 2009 2:23 pm
Added 150cc engine price.
PostPosted: Mon Dec 28, 2009 3:27 pm
It is Engine season. Get your order in early!!
PostPosted: Wed Dec 30, 2009 9:05 am
Do you have any 180cc packages ready to go now or is it an order first deal? I'm intrigued by this as I already planned on swapping to a 150cc. Thanks
The Rucker formerly known as Firekiller352
My build thread. Check it out!
viewtopic.php?f=93&t=46200
ComposiMo
JustForRucks/Ruck1Built
MOPED MOTION
PostPosted: Wed Dec 30, 2009 10:35 am
Each engine is custom built. It usually take less than two weeks to get one built.
PostPosted: Wed Dec 30, 2009 12:24 pm
Shipped to 34474? That's FL.
ComposiMo
MOPED MOTION
PostPosted: Tue Jan 05, 2010 8:23 am
Engine season!!! Get them now!!
PostPosted: Tue Jan 05, 2010 8:31 am
Uh oh, someone wants more speeeeeed! haha!
ComposiMo Fabrication - Billet Aluminum Motor Mount Kits, Ruckus Accessories, Open CVT Belt Drive Covers, and MUCH More!
http://facebook.com/composimo.fabrication
http://instagram.com/composimo
PostPosted: Tue Jan 05, 2010 8:42 am
Haven't fired mine up yet, but I had KS do a custom build for me. good communication, shipping was fast & well packaged motor. roughly 2 weeks even during the holidays.
