 Post subject: Custom Nissin Front Caliper
PostPosted: Mon Feb 09, 2015 12:58 pm
Has anyone seen this done, or know if it would even be possible? I'd imagine with a custom bracket made, these could be mounted on the front and used.
My Ruckus | http://oi62.tinypic.com/znm0qu.jpg
 Post subject: Re: Custom Nissin Front Caliper
PostPosted: Sat Feb 28, 2015 3:13 pm
No machinists in the community want to get in on this? Come on guys, I wanna see CHALLENGE ACCEPTED!
CANADIUS MAXIMUS
CANADIUS MAXIMUS
PostPosted: Sat Feb 28, 2015 3:22 pm
Ok.....I gotta ask "why?".... :meh:
The Big Ruck is already using a 3 piston nissin on the front, and drum on the rear....I'm not quite getting what you're driving at.
Someplace in here somebody has swapped the rear disk set-up from a Reflex on to the BR
:canuck:
Stimpy433 wrote:
2005 BIGUS Ruckus
viewtopic.php?f=95&t=41664
PostPosted: Sat Feb 28, 2015 5:28 pm
I'm thinkin, he was thinkin, this is the ruckus section, not the BIG Ruckus section, I think.
CANADIUS MAXIMUS
CANADIUS MAXIMUS
PostPosted: Sat Feb 28, 2015 8:40 pm
I'm thinkin, what you're thinkin he's thinkin is right....I think
:canuck:
2005 BIGUS Ruckus
PostPosted: Mon Mar 02, 2015 11:42 am
:canuck:
Wow, you're right :/
Sorry BR crew, this was meant for us little guys.
CANADIUS MAXIMUS
CANADIUS MAXIMUS
PostPosted: Mon Mar 02, 2015 5:43 pm
:lol:
:canuck:
2005 BIGUS Ruckus
PostPosted: Tue Mar 03, 2015 12:10 am
Too much of this, "what color is this dress?" has been messing with my eyes.
PostPosted: Tue Mar 03, 2015 7:13 am
i want to do the same im on a LR i got a tokiko off a gxr 1000 i'll try to find a pic but it looks almost identical. i was gonna cut flat steel to the right shape then space it with washers and measure what i got and have a local machine shop make a custom bracket. i'll see if i can find a pic of the caliper i have
edit found a pic
My ruck "build"
The Asphalt Slayer
T.sracing wrote:
CANADIUS MAXIMUS
CANADIUS MAXIMUS
PostPosted: Tue Mar 03, 2015 8:47 am
Locate where you want the caliper located , have the machine shop/weld shop TIG weld aluminum tabs on the shock body (assuming your lower body is aluminum)
:canuck:
2005 BIGUS Ruckus
PostPosted: Wed Mar 16, 2016 3:03 am
:canuck:
It was me.
Rear swingarm, rear wheel with disc, rear caliper, muffler, exhaust head pipe. All this stuff needed from reflex.
Also lot of fuck with replacement rear brake pipe to steel braided brake hose.
It was worth it?
No.
Another way - try to find Honda Foresight 250 SE. SE version have rear disc brake too. With FES SE replacement, you need only rear wheel and brake caliper. Also need to drill swingarm to inctall caliper. There is small holes witch should be drilled on BR swingarm.
True jedi way - try to find Piaggio x9 250 (With Honda engine). You will get the front 14" wheel, with double disk brake, and rear 13" single disk wheel. Brake system by Brembo. Fucking lot of fuck with swap. But very interesting.
God mode - Vince way.
