 Post subject: Now stocking our favorite signals...
PostPosted: Mon Jun 29, 2015 7:44 am
We've used these as a favorite for some time now. Much cleaner than the OEM signals, yet maintains the signature Ruckus visual. High quality aluminum housings. $34 @ www.mnnthbx.com
 Post subject: Re: Now stocking our favorite signals...
PostPosted: Thu Jul 09, 2015 1:33 pm
Just to be clear, are they LEDs?
I've been looking for something like these for ages...
Red 9 build thread: viewtopic.php?f=93&t=81803
PostPosted: Thu Jul 09, 2015 1:43 pm
Those are tight!
PostPosted: Tue Jul 14, 2015 9:24 pm
I can't tell if they are LEDs or not. Confirmation please!
PostPosted: Sat Jul 18, 2015 7:46 am
Curious about these as well...
PostPosted: Sat Jul 18, 2015 9:10 am
Incandescent.
PostPosted: Sat Apr 16, 2016 11:44 am
They are clear bulbs though. Or at least the set I received had clear bulbs. I loved the look but ended up not using them because Massachusetts requires amber front turn signals. So check your local laws before ordering.
PostPosted: Sat Apr 16, 2016 2:50 pm
So swap bulbs :ucrazy:
LiteW8 wrote:
PostPosted: Sun Apr 17, 2016 4:43 pm
http://www.chaparral-racing.com/product ... -9505.aspx
PostPosted: Mon Jun 27, 2016 4:07 pm
Just got my signals today. I couldn't wait to install them so I rushed right into it as soon as I got home from work.
Super simple install. These blinkers come with the male bullet connectors on them already so it's just plug & play when swapping out the stock signals.
I took a video showing the color and brightness of these... Mainly because I was curious before purchasing. I am very pleased! They look way better than the stock signals!
https://www.youtube.com/watch?v=5M6LCDQy4K4&app=desktop
PostPosted: Tue Jul 05, 2016 6:28 pm
did you have to redrill the holes on the side of the headlight frame to fit the signals in?
PostPosted: Mon Jul 11, 2016 3:51 am
Yes I did. I drilled them out when I relocated my stock signals.
Tip: Remove headlight frame so you don't drill into your battery box. :)
