Post new topic Reply to topic  [ 20 posts ]  Go to page 1, 2  Next
 Post subject: M-Stem (the market's cleanest stem)
PostPosted: Thu Feb 26, 2015 4:04 pm
We're proud to release our new M-Stem. Engineered to have no visible rear hardware, without requiring added girth to hide hardware. Super compact and allows for easy box removal and less cable bind. Self centering. Super solid. Holds 31.8mm fat bars. www.mnnthbx.com
 Post subject: Re: M-Stem (the market's cleanest stem)
PostPosted: Thu Feb 26, 2015 4:45 pm
ruck1built
Quality. Custom. Fabrication.
Z125 Crew
PostPosted: Thu Feb 26, 2015 5:11 pm
clean as hell. nice piece!!!
But how does it stay straight? Im a little confused on how it attaches to the triptree bar. :popcorn:
PostPosted: Thu Feb 26, 2015 5:27 pm
Im assuming the bolt goes through the front behind the bar. The stem is probably threaded to except the bolt.
ruck1built
Z125 Crew
PostPosted: Thu Feb 26, 2015 5:44 pm
Running a bolt through it into a tapped hole would do it, but requires a lot of added meat to the back, some wanky nut maybe, and would probably be sloppy side to side. We used some creative engineering and went the extra mile to avoid all that. We do use the OEM hole though.
PostPosted: Thu Feb 26, 2015 8:38 pm
As always. ...nice stuff Greg. :highfive:
PostPosted: Thu Feb 26, 2015 8:46 pm
pic of the bottom? and will hardware be offered for those of us wanting to keep the stock speedo
PostPosted: Thu Feb 26, 2015 9:04 pm
I stand corrected. :highfive:
ruck1built
Z125 Crew
PostPosted: Thu Feb 26, 2015 9:05 pm
That's some sweet assed shit right there.....
Good job Greg! As usual. :D
PostPosted: Fri Feb 27, 2015 6:30 am
No. We want to keep it simple and clean. We normally run the Vapor or no speedo at all. I can get a pic of the bottom, but it's flat and featureless. No pockets, holes, or anything.
PostPosted: Fri Feb 27, 2015 6:47 am
as soon as my exhaust sells i am getting one of these ive decided that briggs exhaust with quality steering is safer than a nice exhaust with ebay stems and shims
My ruck "build"
The Asphalt Slayer
T.sracing wrote:
PostPosted: Fri Feb 27, 2015 2:52 pm
hmmm might need to put in an order. what over all length do you recommend for Ruckus Bars?
Also if you found some perfect 1 1/8th sized bars would those work?
I'm guessing the M-Stem will work with bars 7/8th to 1 1/4th thickness at the clamp?
PostPosted: Fri Feb 27, 2015 6:42 pm
It will fit only a 31.8mm bar. We went that way because there's a million options, and they're readily available. In fact, we'll soon be stocking them. It's what we've always run, and I field "What bars are those?" and "where do I get them" questions continuously, so we figured its time to carry them, as the demand is there...
PostPosted: Sat Feb 28, 2015 5:54 am
Another great n clean looking part from the G Man :highfive:
PostPosted: Sun Mar 15, 2015 8:28 pm
Ordered mine last night and got a tracking number today awesome service can't wait to GET it on the bike
My ruck "build"
The Asphalt Slayer
