Post new topic Reply to topic  [ 85 posts ]  Go to page 1, 2, 3, 4, 5, 6  Next
 Post subject: MAKOA 11 POLE PLUG AND PLAY GY6 HARNESS NEW LOW PRICE!!!
PostPosted: Wed Nov 04, 2009 7:40 am
BY POPULAR DEMAND!!! ASK AND YOU SHALL RECEIVE!!! NEW LOW PRICE FOR THE WINTER $299 plus FREE 2-3 Day Priority Shipping
Okay KIDS! PLUG AND PLAY 11 Pole GY6 SWAP HARNESS to OEM Hand Controls
You will need a Vacuum Fuel pump to work with this harness, and also the OEM Gas light will not work.
GY6 11 Pole Wire Harness
GY6 to OEM Ruckus Controls less the ECU,Fuel light and Electronic Fuel Pump -
****You will need an 11 Pole Stator, Flywheel and Rectifier****
****For Customers without an OEM Harness Core, you will need to purchase a Starter Relay for the Fuse Box. That would be the Light Blue Relay on the Right - I do offer them for an additional $12****
Harness is hand built, Please allow up to 1 week until time of delivery.
$299 plus FREE Shipping.
[/b]
PLUG AND PLAY STATOR
PLUG AND PLAY RECTIFIER
ALOHA! :wavehello
INSTALLATION PICTURES
Battery Fuse-Box Connections
Tail Light Connections
Stage6 Fuel Connections
Right_Hand_Control and High Beam Connections
OEM Speedo Light Connections
Met Float Connections
Ignition Connections
GY6 Flasher Relay Connections
GY6 Engine Ground Connection
GY6 11 Pole Stator Connections
Coil Connections
Chassis/Front Frame Ground Connection
CDI Connections
Brake Switch Connections
Accessory and Kill Switch Relay
Signal Light Indicator
CDI Connection
Coil Connection
Front Chassis Ground
Fuel Gauge Connection
Headlight Connection
Signal Power Connection
High Beam Indicator Connection
Left Hand Controls
Rear Ground (Engine) Connector
Right Hand Connector
Starter Connector (Need to Splice into Starter Cable provided with Engine)
Tail Light Connectors
ALOHA! :wavehello
MAKOA SCOOTERS
Patron Saint of TR
Patron Saint of TR
 Post subject: Re: MAKOA 11 POLE PLUG AND PLAY GY6 HARNESS
PostPosted: Wed Nov 04, 2009 7:47 am
Best wiring harness ever!!!! :banger:
The "Addiction"
SSBC: Under Compensating Daily Since 2008
TT-350z wrote:
thats like me rocking ssbc stickers without meeting stimpy :twisted:
PostPosted: Wed Nov 04, 2009 8:06 am
ABSOLUTELY the best!!! I got this harness in my Ruck... Easy as pie to hook up, and works PERFECT!
Thanks Jay!!! :banger:
ComposiMo Fabrication - Billet Aluminum Motor Mount Kits, Ruckus Accessories, Open CVT Belt Drive Covers, and MUCH More!
http://facebook.com/composimo.fabrication
http://instagram.com/composimo
PostPosted: Wed Nov 04, 2009 10:06 am
I too have this harness awsome quality, no cutting, splicing super ez install and excellent customer service!!!
-Mark-
PostPosted: Thu Nov 05, 2009 12:32 pm
bump for my homie!
SpeedLounge Photographer
http://www.SpeedLounge.com
http://www.BrianCPhotography.com
http://makoascooters.com/
North East Ruckus Dudes
PostPosted: Sun Dec 06, 2009 9:15 am
mine still going, i get the original makoa scooters harness. :banger: :banger: :banger: and the best part is mine is made in hawaii
SPREAD THE ALOHA!! no need be hawaiian for ALOHA stop the drama stop the hate.
PostPosted: Sun Dec 06, 2009 9:17 am
Send me one f those 11 pole thingys with that Rocker setup too. I'll Paypal right now :wasted:
 Post subject: Re: MAKOA 11 POLE PLUG AND PLAY GY6 HARNESS XMAS SALE!!!
PostPosted: Tue Dec 22, 2009 5:42 pm
XMAS SALE!!!!
$350+18 Shipping
ALOHA! and MELE KALIKI MAKA!
ALOHA! :wavehello
MAKOA SCOOTERS
 Post subject: Re: MAKOA 11 POLE PLUG AND PLAY GY6 HARNESS SALE!!!
PostPosted: Mon May 03, 2010 3:46 pm
Is it possible to set this harness up to work with the OEM gas light?
My Build Project "Sukcur Punch"
PostPosted: Mon May 03, 2010 8:04 pm
It is made to run OEM lights.
ALOHA! :wavehello
MAKOA SCOOTERS
PostPosted: Mon May 03, 2010 10:17 pm
Sorry my comment might have been confusing. I assumed it ran the stock "headlights" but noticed the listing said "less the fuel light" and I was inquiring if your harness could be set up to work with the stock fuel light/gas level indicator light?
PostPosted: Tue May 04, 2010 6:48 am
Sorry, I do not incorporate the Fuel Light or OEM Fuel Pump. You will need to get a Met Float and a Stage 6 Fuel Gauge, which my harness is built for.
ALOHA! :wavehello
MAKOA SCOOTERS
PostPosted: Sat Jan 08, 2011 2:40 pm
Still making these bad boys?
My 2009 Stretched fatty big bored and stroked build thread...
viewtopic.php?f=95&t=47164&p=753763#p753763
PostPosted: Sat Jan 08, 2011 4:01 pm
You GOT PM!
ALOHA! :wavehello
MAKOA SCOOTERS
PostPosted: Mon Jan 10, 2011 10:04 am
Tops for Makoa. Still the best harness out there :banger:
_
