Post new topic Reply to topic  [ 42 posts ]  Go to page 1, 2, 3  Next
 Post subject: Scooter Missions S2 Fat Tire kit
PostPosted: Sat Feb 20, 2010 9:40 am
Anyone use this kit? Am I right in reading that I would just have to have the right exhaust and obviously a tire and be done? Here is the site, its down at the bottom: scootermission.com
My "built not bought" build thread --> viewtopic.php?f=92&t=48976
"Anything less, is everything else."
2010 King of HATE
2010 King of HATE
 Post subject: Re: Scooter Missions S2 Fat Tire kit
PostPosted: Sun Feb 21, 2010 1:16 am
correct
Bikes 4SALE
'08 Ruckus $2.5k
'10 Elite 110 $3k
'98 Superhawk $3k w/extras
'74 CB550 $2k
Replace w/ GROM + Either cb1100 OR cb1000r
MANdown
PostPosted: Sun Feb 21, 2010 5:40 am
I was one of the first to purchase this kit...and the first to run the Innova tire on it. Kit works flawlessly, if you plan on mounting a "round fatty" tire then this kit is simply mount and go. I had to fab a spacer to put over the spline to push the tire away from the drive case...cause it rubbed. As far as the exhaust go's i bought the carbon fiber Yosh TRC exhaust. This has the mounting flange welded to the pipe so i had to bend the pipe and really bend the mounting bracket to clear the innova tire. If you don't want to do that then buy the "clocked" gokubuto version from Bowls (which is always sold out) or seek a different style exhaust. I know Scooter Missions site says a yosh will work, but the TRC yosh needs some modifying to clear any fatty tire.
Here are some vids of me taking my S2 fatty for its maiden voyage, before i re-jetted the carb.
http://www.youtube.com/watch?v=1Q4omSJqiGI
http://www.youtube.com/watch?v=dkiI8xl_MH0
http://www.youtube.com/watch?v=HRBYUHNQDhE
P.S. you better have aftermarket handlebars (lower than stock) or your stock brake and throttle cables won't be long enough. You'll prolly have to extend your fuel line as well. Most stretch kits come with longer cables and fuel line but this kit does not. Just FYI.
MMRC
My ride: viewtopic.php?f=96&t=50571
GORBY GEAR PRODUCTS: http://gorbygear.bigcartel.com/
http://instagram.com/gorbygear
PostPosted: Sun Feb 21, 2010 8:45 am
Thanks for all the info. It looked pretty much mount and go but I figured I would ask. Thanks again.
PostPosted: Mon Feb 22, 2010 11:12 am
i want this on my ruckus so bad. i just went to scottermission but couldnt find the kit on there. what would it be under?
PostPosted: Mon Feb 22, 2010 11:18 am
It was clear down at the bottom of the "ruckus" page.
PostPosted: Mon Feb 22, 2010 12:33 pm
ok thanks man
PostPosted: Tue Feb 23, 2010 2:48 pm
Forgot to mention that if you plan on running the innova tire on this kit you'll need to have a kickstand. The tire rubs on the stock centerstand in the up position, which is no good. You will also have to ditch your stock oil dipstick, or shave the shit out of it. Here are some pics to help you visualize this stuff. Peace.
The difference in size between the stock tire and the Innova Fatty.
Here is a link where i got my tire from:
http://www.atvtireexpress.com/18x1010.html
The tight clearance between the tire and the oil filler area. (Much tighter than it looks)
Oil cap is from Battlescooter.
The final finished product!!
MMRC
PostPosted: Tue Feb 23, 2010 3:07 pm
i think im gonna get this kit. but that spacer shit freaks me out a bit. i aint got no laith and it would suck if i bought it and im stuck with no scoot for awhile
My Build....ing viewtopic.php?f=95&t=54144
PostPosted: Tue Feb 23, 2010 6:16 pm
What would you say if i told you i had them make me two spacers, and the second one is collecting dust in my toolbox? :twisted: Or you can just get a round fatty tire and negate the need for the spacer.
Edit: Also this tire is a bit shorter (overall height) than the stock tire so if your anywhere near or above 200lbs in weight you'll prolly hit your rev limiter around 35mph....at least that's what happend to me....a cdi is the cure for this issue...obviously.
MMRC
PostPosted: Wed Feb 24, 2010 8:43 pm
I have this kit and love it. Only thing is I have a lil lean. Havent had a chance to try and fix it. I am running the 140/90/10 kenda
"Tough times never last, but tough people do"
Build thread viewtopic.php?f=95&t=44420
PostPosted: Thu Feb 25, 2010 10:49 am
Wouldn't you be better off swapping in Met gears? Seems like it would be alot of unnecessary tax on your engine just to hit 40mph...
So, back to the topic.
Don't talking about ruckus with ferrari engine anymore.
MY BUILD THREAD
PostPosted: Thu Feb 25, 2010 2:37 pm
always more than one way to fix a problem... :mrgreen:
MMRC
PostPosted: Mon Mar 01, 2010 3:32 pm
Anyone have a problem with the wheel leaning in towards the shock?
2010 King of HATE
2010 King of HATE
PostPosted: Tue Mar 02, 2010 3:44 am
that's not the wheel leaning in that's the engine leaning to the left.
only true fix is solid engine mount bushings
Bikes 4SALE
'08 Ruckus $2.5k
'10 Elite 110 $3k
'74 CB550 $2k
MANdown
