 Post subject: Looking for information on Gy6 Short swap
PostPosted: Sat Feb 27, 2016 10:07 pm
Hey all
Im looking into purchasing a ruckus and doing a GY6 short swap. I want to keep the looks as similar to the stock ruckus as possible.
Does anyone have any experience with this? Most, if not all, of the guides are for the long case. Also, Im very interested in anyone who may sell a premade kit to do it all in one.
Cheers
 Post subject: Re: Looking for information on Gy6 Short swap
PostPosted: Sun Feb 28, 2016 6:56 am
As far as swapping a gy6 goes, there's no difference in long and short case. Most people go with a long case in order to be able to run larger wheels. Kinda confused by your question
Junk Ruckus: viewtopic.php?f=94&t=66879
Ruck Fink Stickers: viewtopic.php?f=47&t=91889
PostPosted: Sun Feb 28, 2016 10:02 am
Yep, like he said a short case and a long case are exactly the same. Only difference is swing arm length obviously, and the ability to only run smaller wheels. I believe drowsports sells a "kit".
Long case with 8" fat rear tire
http://www.drowsports.com/drowsports-ho ... atty-tire/
Long case with 7" fat rear tire
Note**that is not EVERYthing you need. Just mostly everything.
In my opinion, it's cheaper to make the parts list of things you need, and buy them separately. I spent $1200 solely on my swap. Some people do it cheaper, some go all out with $4k +
this RUdiCKuloUS build
http://totalruckus.com/phpBB3/viewtopic.php?f=93&t=94739
PostPosted: Sun Feb 28, 2016 1:08 pm
Oh, I thought the short was needed to have the ruckus look stock with the Gy6?
Basically what I dont want my ruckus to look like is this :
Something like this is my end goal:
PostPosted: Sun Feb 28, 2016 1:48 pm
You will just need to mount the gy6 further in towards where the stock GET motor mounts. Very limited mounting options for the "no stretch" look. Check out Teamturtleruck's ride on here
Edit: Here ya go...
viewtopic.php?f=96&t=87767&p=1496091#p1496091
PostPosted: Sun Feb 28, 2016 4:14 pm
The picture you want your ruck to look like, has a 12" rim. I'm about 90% sure. Still need a long case motor for that. Anyway, yes you will need to tuck your engine way up in there, as close to the original mounting location as possible. Sweet look though, I like both the stretched and non-stretched.
PostPosted: Sun Feb 28, 2016 8:29 pm
Is there anyone that sells a kit specifically for a non-stretch look?
PostPosted: Sun Feb 28, 2016 10:17 pm
You'll have to do a weld on mount. Check out mojo-customs.com
PostPosted: Tue Mar 01, 2016 5:43 pm
My brother now owns this bike..
It is a custom rear frame made in very small numbers by a guy called "superuck". it is a 12x7 rear rim, and is a long case.
A short case WILL NOT help keep it short. The problem is the engine offset from a fatty. If you want it short, you'll need to stay skinny tire.
Ruck-U, Minnesota Chapter
HRGC Racing
Instagram: greyduckcustoms
Duckwing and keygaurd guy
PostPosted: Tue Mar 01, 2016 8:49 pm
Greyduck, does it still have that exhaust? Is it just a header cut short? How is the sound
PostPosted: Tue Mar 01, 2016 9:33 pm
open header sounds like wet shit on a gy6
just cutting corners on a build if you ask me
