Post new topic Reply to topic  [ 221 posts ]  Go to page Previous  1 ... 10, 11, 12, 13, 14, 15  Next
 Post subject: Re: POST HERE. HELP ME fix my GY6
PostPosted: Fri Feb 07, 2014 2:01 pm
Gy6 is having starter issue. Makes this noise about 4 times. All grounds appear to be correct.
PostPosted: Sun Feb 23, 2014 9:14 pm
Sounds like starter grinding on the gear
Sent from my Nexus 4 using Tapatalk
Gy6 Ruckus - Project Black Ice Sold
09 Zuma Stolen
Forza300 Swapped Ruckus
Ghosts
Ghosts
PostPosted: Thu Apr 10, 2014 11:20 am
Hey guys I'm almost done with my swap and I'm having some wiring issues. This is a killer scooter 11 pole harness, and I have a few basic wiring questions.
Not sure where this goes. It's coming from the front of the harness and the wires are black/red stripe and white/yellow stripe
Also not sure where my auto-choke would plug in, or if it's even needed.
Next are these two wires. I'm pretty sure they go to my solenoid, but which side do they go on?
This is the last cable I'm confused about. It comes out of the solenoid and the colors are yellow/green stripe and yellow/red stripe
Any advice would be great!
2009 Honda Ruckus "Red Monster" http://totalruckus.com/phpBB3/viewtopic.php?f=96&t=56047
2009 White GY6 Ruckus
2007 White Metro
Ghosts
Ghosts
PostPosted: Thu Apr 24, 2014 10:45 am
:meh: bumpp
2007 White Metro
PostPosted: Thu Apr 24, 2014 1:50 pm
First pic is your auto choke plug. Either use it or leave it unplugged. From there, you should have a plug(the white one in your hand) and 2 wires coming from behind the fan shroud(stator). Other than that, a power wire to the starter and your good..
And BTW: make sure you drill and bolt the front of that Killer Scooter mount to the frame. Very important..
Gasmans Gangsta Build
PostPosted: Thu May 01, 2014 9:21 am
Installed a new Mikuni vacum fuel pump down by my fuel tank to replace my other stock fuel pump.
Vacum line fills up with gas bout 2" above the pump.
Drained it a couple of times after a ride.
It is a bother to me or is this normal???
 Post subject: no power to coil gy6 swap
PostPosted: Thu May 01, 2014 8:47 pm
ok i am very new to the ruckus world i have an 06 with gy6 swap i am building. now i bought it as someone else project so o do not know history. i gave got everything hooked up but no spark it cranks all light work everything just no spark. now i have power from stator power into cdi but no power to coil.so any help would be awesome. here are some details the harness is a buggy depot it has a power panel instead of fuse box with 3 wires that go no where one is red,green,black. it also has a 2 relay setup that are 40 amp relays but not for sure what they go to. in advance thanks for help
 Post subject: Re: no power to coil gy6 swap
PostPosted: Thu May 01, 2014 8:56 pm
Most likely a ground issue. Check all of them.
ruck1built
Quality. Custom. Fabrication.
Z125 Crew
PostPosted: Thu May 01, 2014 9:06 pm
ok thank you also the green on stator just while trying to crank
PostPosted: Thu May 01, 2014 9:09 pm
sorry tired i was cranking and the green[color=#000000]wire started to belt coming fron stator[/color]
PostPosted: Thu May 01, 2014 9:10 pm
melt not belt
PostPosted: Thu May 01, 2014 9:16 pm
It melted because you cranked it to much. 3-4 sec blips max. You can't sit there and continuously hold the start button down. Now you need to check the entire thing as you've could've melted something else to.
ruck1built
Z125 Crew
PostPosted: Thu May 01, 2014 9:22 pm
ok also does coil have to be mounted to ground i have mine just hanging for now could that be problem
PostPosted: Thu May 01, 2014 9:28 pm
figured out melting problem i lost ground to engine
PostPosted: Thu May 01, 2014 9:29 pm
still no spark
