Post new topic Reply to topic  [ 221 posts ]  Go to page 1, 2, 3, 4, 5 ... 15  Next
 Post subject: Tuning Question: GY6 w/ Keihin PE24 ***BOGS DOWN at 35mph***
PostPosted: Tue Sep 06, 2011 11:34 am
I was hoping someone can tell me on how to fix my scoot.
This is the symptom:
At first it was bogging down at 20mph and the carb was spitting a lot of fuel. So I took the carb apart and adjusted the float.
The fuel overflow seemed to have stopped and it runs a little better but still bogs down at 35~40mph which is also the max speed at the moment. I have not messed with the jets so everything is stock (MAIN-#115, SLOW=#52). It was running fine when I had the stock gy6 carb so I think it's just the carb.
6y6 150cc
Keihin PE24mm
BTX Exhaust
'09 Honda Ruckus........ $,$$$
800 + km...........$5.00 every oil change
Aftermarket Mods.........$,$$$+
Total Enjoyment........PRICELESS
My Ride: viewtopic.php?t=42552
 Post subject: Re: Tuning Question: GY6 w/ Keihin PE24 ***BOGS DOWN at 35mph***
PostPosted: Tue Sep 06, 2011 11:36 am
Please note, that everything (Gy6, Carb) is pretty much new.
PostPosted: Tue Sep 06, 2011 11:54 am
Sounds like you need to re-jet.
A #52 seems HUGE for a slow jet.
The DTMWHMTSC build
PostPosted: Wed Sep 07, 2011 9:29 am
Any suggestions for the jet size (main/slow)?
6y6 150cc
Keihin PE24mm w/ Stage 6 filter
BTX Exhaust
PostPosted: Wed Sep 07, 2011 10:46 am
I run a #110 main and #40 slow jet and it seems to be just about right. Still tuning myself.
Similar setup to yours, actually.
The DTMWHMTSC build
PostPosted: Wed Sep 07, 2011 11:51 am
GY6 155cc with PE28(it came with the ruck and I believe it's a PE28 because it's measured 28mm inner diameter on the motor side outlet) I had 115 main and 50 slow, it was running very rich... I rejetted with 112 main and 42 slow first, it started up and ran better however it was still on the rich side so I put in 38 slow and it started right up... havent had a chance to test run it cuz my throttle cable got snapped... :headbashing: :headbashing: :headbashing:
my ruck
viewtopic.php?f=92&t=73611
 Post subject: POST HERE. HELP ME fix my GY6
PostPosted: Wed Sep 07, 2011 11:59 am
If it doesn't run right or you are having a trouble with something. Post here and someone will hopefully help you. Read here because your answer might be answered before you ask.
ShuT Em DowN!
Kiwi2Racing.com
You don't choose 2t, 2t chooses you.
ARC! "We fast cause we need to take a sh!t"
ЯTR ̿ ̿̿ ̿̿ '̿'\̵͇̿̿\з=(◣_◢)=ε/̵͇̿̿/'̿'̿ ̿ ̿̿
@longballer
Yellow is Fastest!
 Post subject: Re: POST HERE. HELP ME fix my GY6
PostPosted: Thu Sep 08, 2011 10:13 am
cool. I'm going to try rejetting this weekend and see what happens.
PostPosted: Mon Sep 12, 2011 8:44 am
Do you guys know if the Jets (Main/Slow) from the stock Gy6 carb is compatible with the Keihin PE24?
 Post subject: New Gy6 Swap Not starting please help
PostPosted: Mon Sep 12, 2011 7:55 pm
So i got the battery charged put it fuel in the carb and i try to start it and i hear it cranking loudly but it just doesnt have enough power to finish the startup IM SOOO CLOSE :pissed:
do i have to put gas in the spark plug hole to start it ? and from what i see im going to have to switch out the batter would a 12V 7.5ah battery be okay ? its all i can find around my area !!
http://totalruckus.com/phpBB3/viewtopic.php?f=92&t=59502&p=991701&hilit=dirtybitch#p991701
 Post subject: Re: New Gy6 Swap Not starting please help
oh and i see white smoke coming out of the exhaust is that normal ?
PostPosted: Tue Sep 13, 2011 10:41 pm
Get starter fluid from autozone or any auto parts store and spray a little in the intake of the carb while you try to start it. This will start the engine and create a vacuum to pull the fuel into the carb and you won't have to use the starter fluid after that. Don't hold it an inch from the intake and spray, get a foot or so away and spray it so it's not too much. It may take a few times but it'll work.
Spencerp's...Knocked off 180cc
PostPosted: Fri Sep 16, 2011 8:50 pm
GY6 WONT START? READ THIS!
http://motorcyclephilippines.com/forums ... p?t=243152
06 Ruck **Lucky**
638
FrankiurRuckus wrote:
PostPosted: Mon Sep 19, 2011 9:08 pm
seansean wrote:
Awesome link!
I like cookies
My Ride
PostPosted: Wed Sep 21, 2011 9:39 pm
I had a problem just like this read this viewtopic.php?f=37&t=45996&start=0
and also my pluming was all jacked up
photo dump rides
viewtopic.php?f=95&t=61675
